Originally posted by Darin Jordan
View Post
Bad Kitty! Stop bouncing!!!
Hey Ron,
Very good stuff! I am going to put your intel to work on my MG right away. It appears you were running running a X642, like to know the batteries you were running.
Darin
I am very happy with my MG. I started out with 2s 5000 30c lipos, stock prop. When ever I get my replacement flex shaft, I like to try out another prop or two. Ron was running a x642 which appeared to be a good choice, any other suggestions?
One of the first things I checked was the bottom of my boat, sure enough there are concavities on the ride pads. We used to call that a "hook" back in the day, mostly because we couldn't spell "concavity. Anyway it is not too bad and not to hard to correct. Proboat has no touch up paint. I suggested to the tech support group last week it would be a good to have some to sell to us. Could be a good source of new revenue to boot. This a popular color in the safety business, but I have not found an exact match yet.
I will be interested to see how blackcat26 runs with flat pads! I have to say my first laps on my MG were pretty darn good. I put my batteries a bit forwar of the BP as it was a bit windy, and not knowing the boat, I opted for safety. It wasn't bow heavy really. I am going to try Ron's suggestions, the video was pretty telling that whatever he had done, was working.
I was surprised at the small rooster tail on his boat. Interesting. No matter the development team did a great job on this one! Thank you.
I am in contact with a number RC FE guys and they are all either ordering one or seriously consider it. My guess is will be a winner for Proboat.
Ok here is one last question. How about trim tabs on cats in general and specifically on Miss G? I attached a few pictures of some RC boat trim tabs. I like the long ones best. Your thoughts are invited.
Thank you.
Boomer
Nice run Ron.
Trimmed out nicely, thank you for sharing
I think I would keep the ride pads hook, I like the way it runs in the video.
Almost thought it was designed that way for stability.
Thanks Boomer...
I'm running 45C 5000mah 2S Hyperion packs, the 642 I'm running is thinnned and cupped...
All I can say is, what a great boat. I have to admit I was a little more than apprehensive about running it. A person reads about the wrong cable, the servo problems, and the bouncing issue. All valid problems, I'm sure.. I did change the flex cable and left everything else stock. I'm not part of the Lipo scene....yet, so I used some well used 3000 MAH NiMh's. Even with the junky batteries it ran really well. Balanced at 10 inches from the transom. Very smooth, no bouncing. Radio worked flawlessly. Turned onna dime. Reasonably fast. About 5 minutes of run/fun time. And didn't sink! I know it wasn't running as fast as it could without the big league batteries in it, but still ran excellent! Maybe I just got lucky! I have a x642 to try next, and some new 5000MAH batteries that should be here tomorrow. I hate to buy lipos this late in the season, just to have them sit around all winter. I need opinions on the best kind of lipos to buy and the best charger/balancer to get. but that's for another thread. Maybe next year...I hope.
A very short video http://www.youtube.com/watch?v=DAy-FTMpv_Q
In-d-boatYou're never too old to learn something stupid.
Hey Ron, what voltage were you running in the video? It was not 4s unless you changed the motor out.FE BOATING: Less like a hobby and more like an addiction!
Oops didn't see your answer 2 posts up. You are getting 10 miles an hour faster than me. That prop must be pretty trick bro!FE BOATING: Less like a hobby and more like an addiction!
@blackcat26
It's a very aggresive prop, but I'm running it really shallow, allowing me to spin it at the max rpm. The water was dead calm yesterday and I GPS'd Her at 46.3 I had gun readings the last time out up to 50 flat, but I trust my GPS over the gun.... The first couple passes with those 45C Hyperions are sick! I was loving my 40C TP packs, but the Hyperions are lighter and stronger... I've hit amp spikes to 94amps with the stock esc and haven't popped it yet!
I know props are top secret to some people but would you be kind enough to post some picture of yours? That is truely some impressive speeds on 4s!FE BOATING: Less like a hobby and more like an addiction!
Because the motor in the MG has a low Kv it requires a lot of prop pitch to see high speeds. Props which worked with the BJ should work well with the MG.
The UL-1 motor has a much higher Kv and gives higher speeds with the same prop....but it can also overheat and blow stock ESCs. I datalogged my UL-1 motor in a DarkHorse hydro with an x445 and got average amp draws of over 90 amps. Peak amps were well over 120. It ran cooler and about as fast with an m440 - average amps were under 80. This particular motor needs a smaller diameter prop and may not work too well for general use in the MG. The new 1800 Kv motor in the Stiletto on the other hand.....
I was thinking that also 1800kv would be a good target for this boat. I was eyeing up the stiletto motor prior to receiving my MG knowing that I would want to bump up to a 1800kv motor, but the $98 price tag on that motor steered me away, I then thought about the new sv27r 6 pole 1800kv motor. Designed the same as the ul-1 motor but with a lower kv rating for about $30 less. As of right now I am sticking with my stock power in my mg and running 4s for sport and 5s for serious fun with a x642, bec disabled. Just my 2 cents. After running stock I will run it this way for a while.Originally posted by Fluid View PostThe new 1800 Kv motor in the Stiletto on the other hand.....
Yea what ray said. 2x 2s in series for 4s or 1 3s & 1 2s in series for 5s. 36mph on 4s, 46.4 on 5s both with a x642. Vid in my signature. After seeing the potential on 5s its why I am not rushing to change the stock power yet.
I am in the process of setting up telemetry in my MG right now
Prop questions
Mr. D (Diesel6401)
What is a good price for a x642 prop? Do they all have the same shaft size, or do you have to specify the shaft size? Last one, suggestion on where to buy a x642 to fit Miss G?
(New guy questions. Sorry)
I really enjoyed your videos. In particular the Crash 1 vid. Your boats all seem to be exceptionally fast, so I am wondering if the reason or one reason, for all the flips might be due, at least in part, to your boats running on the "bleeding edge" of the hulls capability? I am sure wind and water conditions are major factors, but the Genesis flip was curious. I was not able to detect any obvious reasons for the boat's "short flight". I have seen other vids of this boat where they looked to be very stable at high speeds. They did show a propensity for torque lift or pitch.
Since I will have mine next week, I would be very interested in your thoughts on correcting torque lift on this boat. My Miss G doesn't exhibit this trait, maybe ever so slightly, but not much.
Don't want to high jack the thread, perhaps you could respond via PM, so as not to disturb the continuity of the thread. Great stuff
Boomer
