BJ 29 v3 running hot help
  • eric113
    • Sep 2011
    • 327
    Thanks for update. I just got MG I was wondering if I need to do anything before I ran it.
    How far did you space the drive dog?
    What I plan on doing before I take out on the water.
    -I have OSE strut, plan installing that and setting the strut height 1/8"
    -Drilling the outlet,inlet,nipple out bigger
    -Make sure the cooling lines are correct
    -Making sure the rudder is straight
    -Take the spacers out at the drive dog and spacing it 4mm
    -Get the prop sharpened and balanced
    -Check the programming of the esc
    • boatsrnew2me
      • Oct 2016
      • 474
      sounds like all the right stuff to do .4mm is plenty . i set my timing at 7.5 . should have new temp readings little later .hopefully even lower .
      • boatsrnew2me
        • Oct 2016
        • 474
        interesting run today . motor temp still 150 when i brought it in . esc was less . motor temp concerns me but i do keep reading that these run hot .
        anyway check the video . had a blowover today .
          • 4335
          New owner of my blackjack ran 59mph last weekend, motor and ESC were both under 110. He's switched to a wire drive and dual cooling rudder since I ran it last.
          • eric113
            • Sep 2011
            • 327
            You know what dual cooling rudder he used?
            • boatsrnew2me
              • Oct 2016
              • 474
              yeah i might try a dual cooling rudder as well . or break down and buy another motor .
              • REDLINE1
                • 199
                This one
                https://www.offshoreelectrics.com/pr...prod=ose-83275
                Had to shorten it , open the hinge pin hole a bit then sandblast and paint black. Added an additional water outlet to the other side of the hull
                • REDLINE1
                  • 199
                  Here's the link to my post on it
                  https://forums.offshoreelectrics.com...pickup-upgrade
                  Did about a 4min run temps were under 110
                  On both motor and esc. Took it back out to finish the packs off hit the lvc. Brought it back in motor was in the 130's and esc was mid 100 and teens. Lakes around here are still pretty cool so I'm not sure if the dual rudder is helping or not
