There isn't any stressing angle on the shaft unless the mod was done incorrectly. The stuffing tube MUST be bent/adjusted as I described, or you will have a sudden angle where the tube meets the strut, which could cause breakage as you encountered. Check out the photos on page 2 to get a better look.
Miss Geico dialed in- strut modification
'89 Hydrostream Vegas XT w/ Mercury 2.4 Bridgeport EFI - 240hp - 95mph
ProBoat Blackjack 29 - 58mph, Traxxas Villain, Traxxas Slash 4x4, Align T-Rex 450pro, Blade mSR, Blade mCPx, Dynam Cessna 182, Blitzworks F/A-18, UM P-51, UM SU-26XP
How did you bend the stuffing tube without kinking it? Did you just keep the flex shaft in it while you bent it?
I gently bend with my hand. You can use a drill bit that just fits in the tube to help protect from kinking as well.
Chief
Sent from my XT890 using Tapatalk 2
You won't need to force it enough to kink it. Just concentrate the bending force near the base of the tube where it exits the hull, then slightly straighten the tube where it approaches the strut-- this is especially important to keep the tube lined up with the strut's downward thrust angle.'89 Hydrostream Vegas XT w/ Mercury 2.4 Bridgeport EFI - 240hp - 95mph
strtu closer to the transom / sponsor is more stable catamaransdsds.jpgLast edited by mannytx1; 01-29-2014, 10:31 AM.
