Miss Geico dialed in- strut modification
  • Speedracer128
    • Apr 2013
    • 288
    #46
    It was choppy and it was still running good. Is that a stock blackjack on 6s with the strut angled down with this mod?
    I need a GPS too
    • hydro_pyro
      • Mar 2013
      • 104
      #47
      Remember to carefully bend the stuffing tube and re-shape it so it's aligned with the sleeve in the strut. Add more bend where the tube exits the hull, and straighten out some of the bend as it approaches the strut.
      '89 Hydrostream Vegas XT w/ Mercury 2.4 Bridgeport EFI - 240hp - 95mph
      ProBoat Blackjack 29 - 58mph, Traxxas Villain, Traxxas Slash 4x4, Align T-Rex 450pro, Blade mSR, Blade mCPx, Dynam Cessna 182, Blitzworks F/A-18, UM P-51, UM SU-26XP
      • kwiktsi
        • Sep 2008
        • 647
        #48
        Originally posted by ozzie-crawl View Post
        Still just the stock one. It is just getting a bit of warmth in it after a 3-4 minutes of running. All plugs are 5.5mm bullets.
        Will try get a some data logging done next weekend see what amps it is pulling.
        Wow, can't believe the stocker is holding up on 6S. How long have you been running it like this?
        • ozzie-crawl
          • Sep 2008
          • 2943
          #49
          I need a GPS too
          Still stock except for motor and prop. Only thing else was the strut mod in this thread. Have not blue printed sponsons yet.
          • ozzie-crawl
            • Sep 2008
            • 2943
            #50
            Only had the boat a couple of weeks so its done about 1 hours worth of running. After a 3-4 minute run every thing is only just warm.
            I reckon i could do a 7-8 min run with out any thing getting hot.
            • BHChieftain
              Fast Electric Addict
              • 2051
              #51
              +1 !!! else you'll see water shooting up the stuffing tube.
              Chief
              • Speedracer128
                • Apr 2013
                • 288
                #52
                What does changing the angle of the stuffing tube do to handling or performance?
                I run my MG on 6s with a 4082 and a 642 or 646 prop. I haven't made any adjustments to my stuffing so I'm wondering if I'm missing something
                • AlanD
                  • Feb 2013
                  • 54
                  #53
                  Ok, so I moved the battery packs to your position. Usual strut down angle. Slight breeze, pretty flat water. The boat ran so nose high at half throttle it was at risk of blowing over and still had a lot of bouncing. I pulled it out after 2 minutes and respositioned the batteries to their "usual" place and ran again. Now I'm back to really flat running with only a little bounce at WOT.
                  My deduction is that my motor must be heavy enough to warrant the cog being between the motor face plate and stuffing tube bulkhead. The lesson learned is that you have to do whats right for your particular setup to get what you want out of it. Here's my setup for what its worth.
                  • hydro_pyro
                    • Mar 2013
                    • 104
                    #54
                    To answer speedracer's question...
                    Notice in the 2nd photo above this post, how the strut shown is angled down, but the strut is not correctly aligned with the stuffing tube. You can see where the angle changes at the joint-- the tube turns upward, but then the strut angles downward. It doesn't affect handling, but correcting the mis-alignment will reduce stress on the flex cable and strut bushing, and help keep water out.
                    The problem is, the stock tube turns and meets the strut at a "level" angle, so it will turn upward when you raise the strut vertically. The modified strut will make this break angle even worse once it's angled down, unless you correct the angle.
                    With the strut removed, bend the tube so the curve is concentrated nearest to the hull bottom. Then straighten out the bend below this point, so the tube is angled downward as it approaches the strut.
                    Alan, correct the tube angle, then raise the strut vertically higher like in my photo above. The bounce will go away.
                    Here's the tube aligned correctly:
                    • hydro_pyro
                      • Mar 2013
                      • 104
                      #55
                      Once the strut is raised high enough and angled downward enough, you will have lots of stern lift effect. This will allow the packs to be moved back more without the blowover risk. Stern lift keeps the back end higher, which will allow the bow to fly higher without the tendency for the tunnel to trap air. Stern lift gives the trapped air an escape path. More speed, more stability, and NO bounce.
                      Note the pack position... No blowover tendency here on 4s.
                      • Speedracer128
                        • Apr 2013
                        • 288
                        #56
                        Thanks for the explanation hydro. I didn't realize the stuffing tube is bendable/flexible when the strut isn't attached
                        I understand what your talking about the air escaping from the tunnel by having the strut higher vertically, but I thought by having the prop deeper in the water was more stable. This weekend I ran my boat on 4s and 6s with the strut set low and angled downward toward the back to keep the nose down and my boat has never been this smooth riding at high speeds since I upgraded my motor. This weekend was ruff where I was running but even when I was going fast when the boat would catch air she stayed level while airborne. With 4s my batts were a out the same position as your pic above with 6s slightly further up. But on mine i made new battery trays that sit lower in the hull. I do know that when I reinforced my hull, the extra weight made my boat handle much differently. I think I need a GPS so I can exactly know how all different adjustments affect its speed
                        • hydro_pyro
                          • Mar 2013
                          • 104
                          #57
                          On some boats, "stable" just means it's stuck more firmly to the water. On a tunnel or catamaran, this traps air and increases the chances of a blow-over. When the strut is higher, there's less prop in the water, and thus there's a lower cross-section of the prop's thrust cone being exerted on the surface of the water. This reduces bow lift and pushes the back end of the boat up, allowing the air to escape out the back, which makes it handle a little more "loose", but more consistent because it's not hopping constantly.
                          • maxmekker
                            • 466
                            #58
                            Originally posted by AlanD View Post
                            https://www.youtube.com/watch?v=_Uln02dfrSs
                            This is my run from Sunday. Still a little bounce at high speed. OSE has a new upgrade strut which should be released this week. I'll be ordering that soon with the M440.
                            cool video man, that thing is fast :-)
                            Drammen rock City
                            • Shane_744
                              Choppin' it up
                              • Sep 2009
                              • 108
                              #59
                              Thanks for the information and pictures on this modification. It took about 1 hour to do this mod to my MG 29. Longest time was bending the stuffing tube correctly and keeping the strut lined up while tightening it. Took the boat out for a quick run and much better. I left the batteries in the same spot that I ran the other day. Bouncing was almost reduced but the bow did wanna lift at full throttle. Boat is otherwise stock. The packs are around the "middle" of battery placement. Ran that for about 2 minutes and the ESC let out some pretty white smoke and black bits.
                              TEAM Crawler Innovations, TEAM Holmes Hobbies, TEAM BC Paints!, TEAM OTTSIX , TEAM Y-Town Crawlers
                              • Arizonaheat
                                • Mar 2013
                                • 43
                                #60
                                Originally posted by BHChieftain View Post
                                Hi,
                                My son has been racing his Miss Geico (V2) in the p-limited offshore class, and we have it dialed in on stock setup with x642 prop. Batteries are just behind the front end of the motor (non-shaft side). Per the tips on the forum, I ground a wider slot in the strut, allowing a bit of negative angle. I have the strut up pretty high-- with the sponsons on the table the shaft does not touch the table-- close-- probably less than 1/8 above it (in the picture it looks like more, but that is just due to the camera angle).
                                In race conditions (ie, some race-induced chop in the water), the boat rides perfect, no bounce. In glass water, we get a slow bounce. I have not blueprinted the sponsons, and probably won't bother as the boat is doing great in race conditions.
                                Been too busy coaching my son through the races to get a video, but will try to get one next time.
                                Chief
                                How do you plan to "blueprint" the sponsons?
                                Is there a dimensional drawing available?
