bad day
  • domwilson
    • 4405
    When you change the speed controller out, if the motor runs backwards, swap any two of the motor leads to get it to rotate in the proper direction.
    Government Moto:
    • mtk
      • Jun 2009
      • 58
      replace the reicever from the sv does it work
      • jlr3rd1
        • 240
        havent tried, my hobby shop looked at it and said that 1 of the capacitor was blown??470 micro frad 50 volts, of course radio shack had one but only 35 volts does that sound right?? they said after finding the part it just needs to be installed???
        2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
        • jlr3rd1
          • 240
          awesome i was able to connect the motor wire from the bj to my sv and the bj RAN:) must be bad esc?
          • domwilson
            • 4405
            The one from radio shack should work. Make sure you have the polarity correct when installing.
            Government Moto:
            • jlr3rd1
              • 240
              really then i am going to get one and have it put on monday :)_ i hope
              • domwilson
                • 4405
                Buying a good soldering iron would be a good investment. Especially when/if you want to solder connectors on batteries, etc. Here is a good page on tips and stuff.. http://www.offshoreelectrics.com/info.php
                Government Moto:
                • jlr3rd1
                  • 240
                  ok and thanks again for your help
                  • jlr3rd1
                    • 240
                    hey anyone have any ideals on how to get the epoxy off the esc??? can only see one screw ???
                    • kookie_guy
                      • 897
                      my brother in laws did the same thing when he was on the stock radio. When he rolled it, it wouldn't run full out, but it would keep pulsing non stop. Luckily, his capacitor only bulged out the top, not blew. Went with spektrum DX3.0 like me, and not a single issue since.
                      • jlr3rd1
                        • 240
                        really thats good to know:) might have to do that?? how much does that setup run??????
                        • kookie_guy
                          • 897
                          I picked mine up at a local shop (Canada) for $250 CAD. It comes with 2 receivers. I use my other one in my e-maxx. Well worth every penny. There are cheaper, just as reliable 2.4 systems out there if you don't need the 2 receivers. Others will be able to chime in on what's out there for less money.
                          The major benefit is that the receiver as a failsafe built into it. When you bind the receiver to the transmitter, the servo position and throttle position at that point becomes your failsafe. If you roll it, just turn off your tx, and you're safe.
                          • domwilson
                            • 4405
                            I think you'll have to use an x-acto knife and dig that one out.
                            Government Moto:
                            • domwilson
                              • 4405
                              Tower hobbies has their own brand and the Tactics for less than $80.00 USD.
                              Government Moto:
                              • jlr3rd1
                                • 240
                                does the Tactics remote have the failsafe feature?? if you roll it, just turn off your tx, and you're safe.
