When you change the speed controller out, if the motor runs backwards, swap any two of the motor leads to get it to rotate in the proper direction.
bad day
havent tried, my hobby shop looked at it and said that 1 of the capacitor was blown??470 micro frad 50 volts, of course radio shack had one but only 35 volts
does that sound right?? they said after finding the part it just needs to be installed???
2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
The one from radio shack should work. Make sure you have the polarity correct when installing.Originally posted by jlr3rd1 View Posthavent tried, my hobby shop looked at it and said that 1 of the capacitor was blown??470 micro frad 50 volts, of course radio shack had one but only 35 volts
does that sound right?? they said after finding the part it just needs to be installed???Government Moto:
Buying a good soldering iron would be a good investment. Especially when/if you want to solder connectors on batteries, etc. Here is a good page on tips and stuff.. http://www.offshoreelectrics.com/info.phpGovernment Moto:
my brother in laws did the same thing when he was on the stock radio. When he rolled it, it wouldn't run full out, but it would keep pulsing non stop. Luckily, his capacitor only bulged out the top, not blew. Went with spektrum DX3.0 like me, and not a single issue since.
I picked mine up at a local shop (Canada) for $250 CAD. It comes with 2 receivers. I use my other one in my e-maxx. Well worth every penny. There are cheaper, just as reliable 2.4 systems out there if you don't need the 2 receivers. Others will be able to chime in on what's out there for less money.Originally posted by jlr3rd1 View Postreally thats good to know:) might have to do that?? how much does that setup run??????
The major benefit is that the receiver as a failsafe built into it. When you bind the receiver to the transmitter, the servo position and throttle position at that point becomes your failsafe. If you roll it, just turn off your tx, and you're safe.
Tower hobbies has their own brand and the Tactics for less than $80.00 USD.Originally posted by kookie_guy View PostI picked mine up at a local shop (Canada) for $250 CAD. It comes with 2 receivers. I use my other one in my e-maxx. Well worth every penny. There are cheaper, just as reliable 2.4 systems out there if you don't need the 2 receivers. Others will be able to chime in on what's out there for less money.
The major benefit is that the receiver as a failsafe built into it. When you bind the receiver to the transmitter, the servo position and throttle position at that point becomes your failsafe. If you roll it, just turn off your tx, and you're safe.Government Moto:
