I Have Just a BJ26 Hull!
  • jdoe153
    • 6
    as i said i just have the hull. im new in the r/c boat area and Im trying to get the boat to go about 40-45 mph range without costing me to much money. Ive read a lot of these posts but cant decide what I need to do to get the maximum speed. I need an esc, motor and batteries. Can anyone give me the ideal setup for speed and reliability for not to high of a price.
  • MAXAMUS
    • 210
    well for a start why not go for the x-power brushless esc and the stock BJ motor bang for buck will get you in the ball park speed figure your looking for if your on a budget but i always say save your $ and go for a better set up which will save you in the long run as the more you get experience with your boat the more you will want from it
    esc .....http://www.offshoreelectrics.com/products.php?cat=75
    motor.......... http://www.offshoreelectrics.com/pro...rod=dh-prb3310
    Maxamus
    • jdoe153
      • 6
      So If I used that set up what would be the most powerful batteries that I could use?
      • MAXAMUS
        • 210
        to keep in your low budget
        a pair of 7.4v 2cell lipo's no lower than 20c and as high mah as you can budget for i used a pair of 2cell 20c 6600mah lipos and achived 41mph with the stock BJ except i had fullers hardware and a x642 prop
        Maxamus
        • jdoe153
          • 6
          Thanks for all the info guys!
          • jdoe153
            • 6
            Okay now if I wanted it in the lower 50 range would that esc allow me to do so?
            • jdoe153
              • 6
              Im not really sure what you are trying to say. Should I not waste my money with the stock motor and upgrade it, or buy a better esc, and hardware?
              • MAXAMUS
                • 210
                yes it would get you in the high end of the 40's but to hit the big 50 you will need more than just stock i would think better props some hardware but iam not saying it cant be done just search this forum for 50 mph and you will find some info your looking for
                Maxamus
                • MAXAMUS
                  • 210
                  what i mean is you get what you pay for i never even put my boat in the water with stock hardware i saved and upgraded first but had order my boat first it was on back order and i waited over 5 weeks and ended up importing it from the US instead
                  basicly you can run a stock boat but after a while you will feel the hunger for more power and speed and with that comes $$$ its a expensive hobby
                  Maxamus
                  • jdoe153
                    • 6
                    yes I have found that out.
