Fixing the BJ26 Handling Issues
  • nate
    • 1702
    #181
    Looks awsome man!
    LMT
    LehnerMotorenTechnik.com
    • siranger
      • Apr 2009
      • 58
      #182
      Originally posted by drew View Post
      Where can I pick up some of those brake line clamps?
      the brake line clamps you can get from i believe any hi performance race shop or hotrod shop. they are about 25 bukcs for a 12 pack.
      • jaybird
        • 12
        #183
        i got a black jack 2 2s smc 6000mah lipo x642 everything else stock and i run in salt water and all i do is flip and barrel roll. is the x 642 good for salt ?or is it because and need to take out the batt trays and change the hardware not lookin to spend a whole lot of cash but lookin to hurt some nitro guys in corners and straits.ill post a video soon.New to rc boats
        • drew
          • Dec 2008
          • 20
          #184
          I run in salt water only and the X642 works great. Take the battery trays out for sure. It will turn flatter with a rudder opposed to a steerable drive.
          • Rusty_Noob
            • Mar 2008
            • 54
            #185
            Siranger, what hardware setup are you running at the back?
            • Chewy6696
              • Apr 2009
              • 14
              #186
              where did you get that antenna ? I would love to have one like that so I dont have it attached to the canopy.
                • 9481
                #187
                What strut depth do you guys like when running fast?
                • tiqueman
                  • Jul 2009
                  • 5866
                  #188
                  Hey all! Newb on the forum and have been followin this one now and again. I think I saw that someone posted about this but Im going to throw in my 2 pennies. I cut about 3/4" off of my turn fins, removed the stock battery trays and built new ones to sit as low as possible. They sit on the the top of the tunnel and have a slight angle down as they go to the sides of the boat. I also made them longer so I had more options in battery placement. I loosened the bolts that hold the turn fins on and noticed w/ out removing them, I could get a couple degrees on them, so for now, thats how they are going to be. Thats all Ive done besides my 642 prop and I see quite a difference in ride attitude as well as turning. Oh, this is with the STOCK DRIVE hardware. No, it doesnt corner like PN43's, but its a heck of a lot better than it was. I read that some had no luck w/ it. Just wanted to let you all know that my experience was better than I thought it would be.
                  -Scott
                  • nutz1207
                    • Jul 2009
                    • 19
                    #189
                    I to am a newb to this and i have also removed my batt trays and lowered them and also lowered the esc. i did try angling the turn fins to match the hull and it was not good. put them back to just a couple of degrees in just as tiqueman did and it is a lot better than stock. I am using the stock drive and stock prop. i also noticed that one of my turn fins had a curve in it and that it did not sit 90 degrees to the back of the boat it had a slight angle out. i did fix it and will see if it changes anything.
                    • sfcoffee
                      • Feb 2010
                      • 13
                      #190
                      Iwas about to test boat with improvements but with stock drive. result, never made it to the river. I slipped on the ice and fell. front of boat is now cracked apart (port bow) that sucks..I smashed my elbow too but that will fix its self..ARGG!!!!
                      • sfcoffee
                        • Feb 2010
                        • 13
                        #191
                        Originally posted by PropNutt43 View Post
                        Steerable drive system:
                        I have replaced the stock drive system with Fullers Catamaran Hardware
                        This drive works excellent especially if you want the BJ26 to turn well both left and right. I have run this setup with the stock motor and brushless esc with the stock prop also with an octura X642 and X442 both detounged. So far I like the performance of the X442 best. Depending on which prop you use you will have to adjust the height and angle differently.
                        [ATTACH]4347[/ATTACH]
                        If you are going to stick with the stock drive system after doing these mods please post your performance results. It would be interesting to know how well they work with that setup.
                        Please remember all these mod locations and positions are starting points. You will need to fine tune them for your boat's setup.
                        The mods with stock drive and prop definatly helped. Although It still flipped fairly easy when i tried to.. Gps showed 33 mph with prop and shaft paralell(sp) and strut up all the way..
                        • macerov91
                          • Apr 2010
                          • 54
                          #192
                          propnut? can you post more pics of your finished product for the rear? i want to see the final position of your fins?
                          • tiqueman
                            • Jul 2009
                            • 5866
                            #193
                            Mace, I just modded mine recently with the hrdwr from OSE. Works fantastic!!!!
                            • macerov91
                              • Apr 2010
                              • 54
                              #194
                              thanks buddy!!!
                              is there a specific measurment?
                              • tiqueman
                                • Jul 2009
                                • 5866
                                #195
                                Originally posted by macerov91 View Post
                                thanks buddy!!!
                                Of what part? the turn fins?
