pics and shakedown run impressions
  • treystoys
    • 180
    Actually, it turns very well, not as bad as my old Drifter S which was what I was expecting. Its only got two quick runs on it. I'll try and get it in the water again this weekend, and I'll post up with some top speed info and a better idea of how it turns with my rudder set up.
    ttyl
    Trey
    • txboatpilot
      • 1805
      Ran my BJ 26 yesterday for the first time, on 4S2P 3700mAh 25C lipos!! Great run time and very fun to drive!! Handles rough water really good for a 26" hull ... The motor seems to be smoother than the SV27.... For a RTR under $300 NEW, I think itis a great little boat!! I will have to try some upgraded hardware next!!
      Nothing like keeping you lipos warm and your prop wet!!
      • treystoys
        • 180
        Alright guys...GPS'd a run today, with 12 IB4200's hot off the charger in the stock battery boxes, and a sharpened balanced x642 I got 48.6mph on the GPS. The cool thing was I probably ran for over 5 minutes before I brought it in out of plain curiosity. Next run, I'm unsure when that'll be, I may try a V or a 21 series 3 blade prop, or possibly keep it simple and step up to an x645...so my goal to go mid 50s continues...more to come.
        Trey
        • txboatpilot
          • 1805
          Did it turn good? Any spin outs?
          • RCprince
            • Jul 2007
            • 1684
            I tried to run a v947 but it just bubbled water like crazy...The 645 worked good for me...But the guys here telling me thats whats eating my ESC's CC need a data logger programmer like Jeti/Hacker, doesn't that BlackJack 26 Brushless look sweet
            Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
            • txboatpilot
              • 1805
              Trey
              Trey, from what I have been told the V-props are more for SAW running. What was the temperature of the esc, motor, and batteries?
              • treystoys
                • 180
                Hey guys, the boat handles reasonably well with the speeds its running, no spin outs at all, I'm sure the stock driveline is very prone to that hence the inclusion of the spin fins. And the introduction of misaligned thrust angles when the drive is turned...that is unless the drive is adjusted perpindicular to the transom...which would be less than optimum for straightline purposes. Again though, I'm not really running this boat for any other reason than just to fart around and see how fast I can get it going, so turning isn't really a big concern. My hardware choice was just based on past experience setting up a nice free running driveline.
                As far as V props being for saw use only, maybe for this boat yes. While they aren't good oval props for most boats, I've used them successfully in both N2 and P hydro for oval racing. In order for a V prop to work right, the driveline must be set to run parellel to the waters surface at all times. The possibility of using them on a cat is probably limited to straightline running, but for what I'm doing it may fit the bill. Also, the 21 series props are another high lift prop, but a bit more forgiving as far as non parrellel running angles, but they are very high pitched, if I recall, they may even have a higher pitch to diameter ratio than the V props.
                TX I don't have a thermometer to tell you any temps, but off hand I'll say the esc and motor were warm but ok, and the batteries were hot but not unberable. This is the first set of 4200s I've used, and they are way more tempramental than the old 2400 nicads and 3000 nihms I've used back in the day. I think Steve Hill said something about them loosing voltage very fast after charging if they are left to sit for any period of time, and I experienced that first hand the other day after charging the batteries the day before running...the boat ran like it was on 6 cells...crazy stuff. Anyhow, today, I took the packs straight off the charger after multiple re-peaks and ran the boat a few minutes after, so the batteries were hot going in the boat to start.
                Short version...lol...I may go buy a thermometer tommorow and start making some notes.
                ttyl
                Trey
                • txboatpilot
                  • 1805
                  Trey, the set up looks clean, I think you have done a great job! How about some video? Mabey with a temp gun reading!LOL HAHAHA
                  • treystoys
                    • 180
                    Hey guys...had a chance to run the boat today with the x645, had I not had the gps, I'd have been telling you guys the boat picked up 5 mph cause it looked faster and lighter on the water, however, the satelites don't lie! The boat was actually almost 3 mph slower. Speed droped from 48.6 to 46.2 mph. Now the crazy part...every single item, batteries, motor and esc were cooler to the touch even though speed was slower, and the 645 obviously loaded the system more...I guess I'm stumped. If the 642 was faster like the gps said, I was expecting higher temps with the 645... My first thought is to try a few props that are smaller or same diameter as the 645, but with higher pitch...like a 2137/3 I also have a p747 I'll try too. And since the smaller of the two 6 series props I tried was actually faster, common sense is telling me that maybe an x640 would be faster yet...who knows.
                    Tell me your thoughts guys and what some of you may have experienced with similar set ups. Again, I'm running 12 matched IB4200s, a Hacker 10L (I think the same as some of the AMMO motors, about 2300KV) and a Hydra120...two gps'd props were x642 (48.6mph) and an x645 (46.2mph)
                    later guys
                    Trey
                    • gabinglagim
                      • Dec 2007
                      • 3
                      Nice setup!
                      Trey, what inline rudder system did you get for your cat? Sorry I'm a nooB and I have only run my blackjack 26 Brushless 4 times which I bought about 2 weeks ago and I am already seeing the problems with the u joint. (I think thats what its called.) I think its time for an upgrade already. Thanks for the help.
                      Tony
                      • treystoys
                        • 180
                        Thanks Tony...I'm not using an inline set up. Its a traditional offset hardware set up. I'm running a Fullers super strut and bracket, and the mini speedmasters rudder with the 2" set back.
                        Trey
                        • treystoys
                          • 180
                          Hey guys...tested a 1640 today, after the 48.6 run with the x642 and the 46 run with the x645, the 1640=poopoo. It ran ok, but the gps read 38 and some change...and the boat was slugish getting up on step...sooo baxk to the 642 props...maybe a normal x640 and the P series props in the mix.
                          Well, just figured I'd update...hopefully next post will be better news.
                          Trey
                          • obrien
                            • 1320
                            I tried a stock prather 220 yesterday and saw 43.6. I will try a couple of tweaks to it, and see what she will do. I have to do some repairs to the hull though. I had a blowover again at 50, and not there is a bit of damage to fix.
                            • Avanti
                              • 1298
                              it was a nasty blow over I was there to witness.
                              I have pics of the runs, but did not get the blow over as that was a later run.
                              The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
                              • RCprince
                                • Jul 2007
                                • 1684
                                I took a brush and epoxied the whole hull, a light layer of 5 minute... I need to get my outboard SV running again and Start on my BJ outboard
