Just get some 3/16 brass tube (K&S 129) and cut a piece to fit.
prop and sleeves
IMPBA 20481S D-12
As eggneg said but you will also need the K&S 128 tubing inside to adapt the the prop shaft to the 3/16 th inch prop. use CA glue or better yet, contact Jeff Wohlt and he can make the adapter for 6 bucks out of stainless steel. You will need a new drive dog and a longer drive dog set screw but once you are set up it is worth it. 2 2s lippos are the only way to go!
