prop and sleeves
  • egneg
    • 4664
    Just get some 3/16 brass tube (K&S 129) and cut a piece to fit.
    IMPBA 20481S D-12
    • macerov91
      • Apr 2010
      • 51
      hey do u have a link for that i can only find it in a 12 pack...
      • egneg
        • 4664
        http://www.offshoreelectrics.com/pro...6+Brass+Tubing
        Also just about any hobby shop will have it.
        IMPBA 20481S D-12
        • bwells
          • Jan 2009
          • 842
          As eggneg said but you will also need the K&S 128 tubing inside to adapt the the prop shaft to the 3/16 th inch prop. use CA glue or better yet, contact Jeff Wohlt and he can make the adapter for 6 bucks out of stainless steel. You will need a new drive dog and a longer drive dog set screw but once you are set up it is worth it. 2 2s lippos are the only way to go!
          • G-UNIT
            • 949
            When I did mine I did'ent have to do anything but installed the sleeve from the plasiic prop into the new one.
            Make sure you always check your collet nut is tight, also any set screws and your prop nut.
            • macerov91
              • Apr 2010
              • 51
              ok you guys talked me into it which drive should I get can you send me the link to the complete set up! I'm ready to beat the *!***!***!***!** out of my friends
              • macerov91
                • Apr 2010
                • 51
                how do i get ahold of that Jeff Wohlt guy?
                • egneg
                  • 4664
                  http://forums.offshoreelectrics.com/member.php?u=713
                  Click on "about me".
                  IMPBA 20481S D-12
