Some problems on 5S.
  • 6S HYDRO
    • 1325
    T it off if you need 2 seperate cold hoses
    • Eggy
      • Jun 2009
      • 152
      I have raised the water intakes about 1" so that they are at level with the top of the prop now. Will try it like this before going down to 1 intake. Temps are a OK now, getting tops 120F on the caps, but i think that if i reduce it to one intake the temps might climb a bit and could be seeing 130F on the caps.
      • 6S HYDRO
        • 1325
        add a 50v 1000uf cap from radio shack and your caps will stay cool as a cucumber
        • Eggy
          • Jun 2009
          • 152
          Will look into that later, will first try some runs with the intakes raised and tighten the rudder so it does not wobble.
          • Flying Scotsman
            Fast Electric Adict!
            • Jun 2007
            • 5195
            Originally posted by 6S HYDRO View Post
            to i agree the rudder pickup is not enough flow- it only flows in turns.
            Bollocks!!
            Douggie
            • 6S HYDRO
              • 1325
              Originally posted by Flying Scotsman View Post
              Bollocks!!
              Douggie
              english please
              • Eggy
                • Jun 2009
                • 152
                The rudder is for sure picking up water on the straits as well. When i dont block the top of the rudder i see a clear stream of water standing about 7-10" up from the rudder. I will try some different options and see what workes the best:
                - Two pickups and forget about the rudder pickup
                - One pickup in addition to the rudder pickup
                - Only the rudder pickup split with a Y.
                english please
                Bollocks = BS, BullS***
                • 6S HYDRO
                  • 1325
                  try taking off the tubes and running the strait pickups open and watch how high they spew, guarantee 4-5 times the height. hence way more flow in the straights
                  • Eggy
                    • Jun 2009
                    • 152
                    Did some runs today and looked good. The water was nice and clear and almost no wind.
                    Did tighten up the rudder with a washer, raised the water pickups about 1" and raised the strut about 1/8", worked like a sharm. Clocked the boat in at a topspeed of 48.4Mph so i'm back on track now. It was dead stable at that speed, some playing with COG and strut and 50Mph should be next.
