Some problems on 5S.
  • Eggy
    • Jun 2009
    • 152
    Just went out for some runs with the fullers hardware. The water was crystal clear so i was hoping for good runs.
    At 4s the boat looked good, and where stable even with WOT doing around 30Mph.
    But when changing to 5S i encountered some problems.
    First of i am not able to hit full trottle right away, when giving full trottle the prop starts spinning for about a sec and then stops, i have to gently press the trottle and then slowly start building revs. This problem happend after changing to the fullers hardware. Workes like a sharm on 4s but not 5s.
    Also when passing 40Mph the boat starts to get realy unstable. Before changing to the fullers i where getting good and stable runs at 45Mph, but not anymore.
    It looks like the right side is sticking lower into the water than the left, even when having slightly heavier lipos on the left (added some lead to the 2S packs so they are about 60grams lighter than the 3s) I might think that the rudder may couse the boat to be unstable. The rudder is a bit loose so might be the problem, any other ideas?
  • domwilson
    • 4411
    Is this the Stock ESC? Are you running a receiver pack? Do you have pics of the new installation from the back and side?
    Government Moto:
    • Eggy
      • Jun 2009
      • 152
      Stock ESC, temp never been above 110F on the ESC it self and 120F on the Caps.
      Using the Castle BEC. Will get some shots from the transome in some hours.
      • domwilson
        • 4411
        Try reprogramming the ESC. I've heard others say that they sometimes need to be reprogrammed with 5s.
        Government Moto:
        • Eggy
          • Jun 2009
          • 152
          Ok, will try that. How do you other guys using fullers hardware sort out the rudder? Do you run with it when its a bit loose or have you done something to tighten everything up?
          • Eggy
            • Jun 2009
            • 152
            Got some pics of the transom. They are not the best, taken with my phone becouse the other camera was out of power. Let me know if you spot anything and tell me if i should get the other camera to get some better pics.
            • Flying Scotsman
              Fast Electric Adict!
              • 5195
              One thing, I note is no gap between the prop and the strut, you should have at least a 3mm gap.
              Douggie
              • domwilson
                • 4411
                Douggie
                I noticed that too. And you may want to raise the strut up around 3/16" and make sure it is parallel with the bottom of the hull.
                Government Moto:
                • Eggy
                  • Jun 2009
                  • 152
                  Ok, will sort out those things, there is a small gap between the strut and prop, but only 1mm and not as much as 3mm.
                  But can this two things couse the boat to get unstable at 40Mph as far as i can see this things is only preformance issues and will not couse the boat to get unstable.
                  Have also tried reprogramming the ESC to sort of the trottle issue on 5s, but did not work. Will try to set the Low Voltage Cutoff to Low to try if this might be the fault.
                  • domwilson
                    • 4411
                    The strut height and angle can affect stability as well as performance. On the rudder being loose, is that up and down or wobble. Somebody else on here had the same problem and said that a couple of washers on the rudder shaft fixed the problem. Have you tried running without the turn fins?
                    Government Moto:
                    • Eggy
                      • Jun 2009
                      • 152
                      The rudder wobbles a bit, think i have sorted this now by placing a small spring washer between the rudder and the mount for it.
                      Have not tried running without the turnfins. But i dont think that is the case here, ran a stable 48Mph run with the outdrive and turnfins once and after that i ran several Mid 40 runs so the turnfins should be fine.
                      • LiPo Power
                        DJI Drone Advanced Pilot
                        • 3678
                        Higher the speeds, more precise your turn trim angle have to be. I noticed that you have them bent inwards. Make sure they are the same angle. My fullers rudder was loose on its mounting point, bushing, when my boat was doing exactly what yours is doing on high speed. It was sent to Mr. Huller for rework and right after rebuilt there is no more crazy bouncing left to right. Eliminate any play on your rudder to servo connection. All of the above will get you 50.
                        My 3 cents.......
                        Canada
                        • Eggy
                          • Jun 2009
                          • 152
                          As i said above, ran a stable 48Mph runs and several stable mid 40 runs on the turnfins with the outdrive so they should be fine. The angle on them are the same.
                          I will work on the rudder, i will bet that's what's making the boat unstable.
                          • Flying Scotsman
                            • 5195
                            Another point remove the dual water pickups and go with the rudder method
                            Douggie
                            • 6S HYDRO
                              • 1325
                              to much disruption of flow off the prop with those big water pickups- i agree the rudder pickup is not enough flow- it only flows in turns. but yours are too big- use one and line it up w/ the rudder so you only have one drag point not 3
