Just joined the Zelos 36" club today
  • MADRCER
    • Feb 2017
    • 765
    #31
    Depends on what you call not ideal conditions. Small amounts of chop is ok, but with significant chop you might want to get yourself a fiberglass repair kit and spare motors. I have ran my x447's from Dasboata on rough stuff and with no issues at all and got 71.2 out of them in pretty much any water I put my boat in. Got have a good balance with the 1814's or you could be like cheek and chong...
    • vinnyp
      • Mar 2017
      • 283
      #32
      This video I posted a while ago will give a pretty good idea of what the water is like here on a good day.
        • 4340
        #33
        https://www.youtube.com/watch?v=kCbK...ature=youtu.be
        That water is fine. I was expecting white caps!
        • mikiek
          • Apr 2017
          • 191
          #34
          So given the water shown in the video what would be the prop recommendation?
          May your batteries never fail you...
          Mike
          • MADRCER
            • Feb 2017
            • 765
            #35
            x447...Hit Dasboata up I bet he has some.
            • vinnyp
              • Mar 2017
              • 283
              #36
              I ordered a pair of x447's from OSE. I also ordered an 1814-17-45(2) clr. The cll is on backorder. I was thinking of going for a set of props done by someone from OSE, but decided against it. I want to learn how to do this myself. Having more experienced guys lead me in the right direction is great and appreciated. However, having someone do the custom work for me is not the way I learned how to make full sized boats faster and wont be the way I learn how to make these boats faster.
              • Keagan-Z06
                • Mar 2016
                • 970
                #37
                Hope to see you on the Zelos Fast List soon. You can get a pretty good idea what props works well in that thread.
                • Erroneous
                  • Apr 2016
                  • 451
                  #38
                  IMG_0764.jpg. Getting ready to start.
                  • MADRCER
                    • Feb 2017
                    • 765
                    #39
                    According to SMC's website, the 7200 MAH weigh in @ 16.47 oz. Not much more than 5000 MAH. I don't think that is my problem. The struts were @ 4mm. As I look at more You-Tube videos of these boats running, the water they are running is much flatter than what I have here. The boats in the videos are running bow high, packing air, not bouncing around at all. Don't think mine will ever be able to run like that, unless I find another place to run. I am sure the bumps are costing me considerable amounts of speed.
                    Since I attempted to work my props myself, it is totally possible that they are not right. My boat didn't come with any other props. I am trying to get a set of ABC 1814-17-45(2) from OSE. However, the left hand prop is out of stock.
                    Like the full sized boats I work on, trial and error is the only way to make performance gains. Only I have been doing that for 30 years, only messing with RC boats for 30 DAYS!!!!
                    For what it's worth....The weight of your 4 batteries combined are 10oz heavier than the 4 batteries I ran 77mph stock with.
                    I didn't have a clue on what to do to a prop when I started in this hobby and most Pros that work on props that is their livelihood and some don't want to give away their secrets or they could risk seeing a decline in business. So I look around for cheap props that have been balanced and sharpened people sell very cheap from time to time to compare to my stock props if I find a prop that works a significantly better than my stock prop I will try to mimic detail of that one on to one of mine myself and see what happens. If I want to eliminate all possibilities of esc/motor, or set up issues, I fork out the bucks for a professionally prepped prop. Good luck, and let us know how your speeds turn out.
                    • vinnyp
                      • Mar 2017
                      • 283
                      #40
                      Originally posted by Erroneous View Post
                      [ATTACH=CONFIG]151714[/ATTACH]. Getting ready to start.
                      I am looking into doing the same thing, particularly since you guys think my batteries are on the heavy side.
                      • vinnyp
                        • Mar 2017
                        • 283
                        #41
                        I hear you madrcer. Trial and error is the plan. Most times, error!!! Spending the $$ on a set of pro props is not the issue, as it will probably cost me more to screw up several props myself.
                        • MADRCER
                          • Feb 2017
                          • 765
                          #42
                          I hear you madrcer. Trail and error is the plan. Most times, error!!! Spending the $$ on a set of pro props is not the issue, as it will probably cost me more to screw up several props myself.
                          Me too!! LOL..
                          • mikiek
                            • Apr 2017
                            • 191
                            #43
                            Aawwh man! - More $$$ - just what I need
                            Mike
                            • vinnyp
                              • Mar 2017
                              • 283
                              #44
                              I got to take the Zelos out for a run today. Did better, still room for improvement. The water was pretty flat. Had the packs as far back as possible, struts at 4mm. Running Octuro x447 that I sharpened, thinned and balanced myself. Boat ran well. Seemed to be running on the rear 2 pads like it should be. Decent speed#, at least for me so far. Didn't flip it, no other crash at all. However, when I came back in, I noticed 1 blade on stb prop must have hit something. Don't know when it happened. could have been in the beginning of the run, maybe at the end. Not sure if it hurt speed #'s or not. I am sure it will, but not sure if the GPS recorded top speed before or after it was damaged. No big deal as far as the prop goes, I was planning to detongue them anyway.
                              There was an issue that bugs me. When I came back in, the hull had a lot of water in it. I found that the inner forward edge of the stb sponson, right where the 2 halves of the hull meet is cracked and letting water in. Must have happened last time I ran it, but I didn't notice it. This prompted me to expedite my plan of re-enforcing the hull. I stripped the hull down. Got it ready for some carbon fiber laminate to be installed under the battery tray, between the sponsons. Once the battery tray was out, I found the hull to be real soft there. Easily pushed it down with 1 finger. Got the carbon fiber cut out and ready to go, but didn't glue it in. I just want to make sure the hull is 100% dried out, before attempting this. BTW, the flotation that the boat comes with, was saturated with water. That crack must open up under load and allow water to spray in.
                              I am pretty sure I know how to handle the carbon fiber under the battery tray. What is the best option to strengthen the forward part of the hull, under the deck. I can get my hands under the deck a bit to lay down some carbon fiber between the sponsons, but no way to reach where the crack is. I can fix the crack from the outside, but I want to strengthen that area. I have read that some guys pour a few ounces or resin in , others say fill the entire bow with non expanding foam. I am not liking the foam idea. What if it gets wet? Will it dry out? What is the best way to go with this.
                              • Erroneous
                                • Apr 2016
                                • 451
                                #45
                                Looks like the prop warped. Thinned too much?..
