Just joined the Zelos 36" club today
  • vinnyp
    • Mar 2017
    • 283
    That is in Zachs Bay, its part of Jones Beach. The bad part is that it is salt water. That arena in the background is actually an amphi-theatre. There are concerts there during the summer months. Pretty cool to go to, unless you get a bad day weather wise.
    Yes, I figured out running slower into the wind and faster going with the wind.... after I flipped it!
    • mikiek
      • Apr 2017
      • 191
      Good to hear you were incident free. Does it really count as a flip if you land right side up?
      Were you running with the 4 3S? If yes, where did you place them? Also wondering if the batteries were still in place afterwards?
      May your batteries never fail you...
      Mike
      • vinnyp
        • Mar 2017
        • 283
        Yes, I am running 4 3s lipos. These...
        I have all 4 lipos pushed as far forward as possible. After the flip, the front lipos shifted around. The rears, stayed pretty good. Being that the front lipos are kind of stuffed under the deck, I cant get 2 hold down straps around them. I was thinking of using Velcro, but the lipos fit a bit tight under the deck, I don't know if I could get them out if they are held down with Velcro.
        • mikiek
          • Apr 2017
          • 191
          Very reasonable price for those.
          I suppose as long as you can keep the rear batteries in place the front ones can't do too much damage. I assume yours came with the pool noodles up in the hull. Just wondering - when I hit the wall one came loose. It must have slammed into the motor and knocked that out of alignment which then sheared the cable. I'm sure you probably did, but check the components and make sure they are screwed in tight.
          I think having an incident like in your video or mine is not a totally bad thing. It keeps us honest
          Mike
          • REDLINE1
            • 199
            Did the same thing last weekend wish I had a video lol. Perfect back flip lots of big air landed perfectly lol. Make sure u check your struts mine got knocked out of wack on the landing
            As far as the batteries I use a Velcro strip as wide as the battery. For the front ones I have a thin plastic ruler which is the same width as the batteries Lay the ruler on top of the velcroed battery tray all the way forward under the hull , slide the battery in on top of the ruler then pull the ruler out. To remove the battery reverse the process by lifting up on the rear of the battery and working the ruler in under to separate the Velcro then slide the battery out
            Even after my flip none of the batteries moved Velcro worked great
            • TheShaughnessy
              • 1461
              A little trick I learned somewhere along the way concerning Velcro and stuck batteries. Ill try to find a pic but for now i'll do my best to explain it. Get a flexible ruler, or any thin sheet of metal, place it on top of the Velcro in the boat, slide the battery in, slide the ruler out. To remove them you wiggle the ruler back in and it keeps the Velcro from re hooking everything.
              • vinnyp
                • Mar 2017
                • 283
                Thanks for the tips on mounting the lipos. I'll look into that.
                • vinnyp
                  • Mar 2017
                  • 283
                  Yesterday, I finally got the time and had good weather to take my second run with the Zelos. I won a Garmin Forerunner on EBay as well, so I had some #'s to work with. Although I am definitely a novice, I was still expecting better #'s. Unfortunately, I have no videos, since I went alone. The water was as flat as its going to be here. Not like you lake guys, but flat enough. I had the struts set to 4mm, had 4 3S lipos as far forward as possible. The boat seemed to be running slightly wet, but I decided to leave it as it was and run it. With the exception of me detounging and sharpening the props, they are what came with the boat from Horizon. I haven't messed around with any ESC calibration or programming. They are as they came.
                  I see the speed #'s you guys are posting here. I am no where near that, even compared to the guys still running stock electronics. I am starting to think either I destroyed my props by me screwing around with them, or something is off with the ESC calibrations, or maybe I just suck and should stick to full sized boats. Am I expecting too much from my second run?
                  • MADRCER
                    • Feb 2017
                    • 765
                    Sounds like you might have something amiss. Bring them batteries back some. Those 7200mah SMC'S are heavier than most 3s packs and they are probably holding the nose down too much, especially with 4 of them. I ran 62.2 mph with a stock boat virtually untouched, you should be able to get more than 54.
                    • mikiek
                      • Apr 2017
                      • 191
                      Hey Vinny - seems like batteries are a mixed blessing. Do you have any other 3S batteries to compare the 7200mah to? Or can you weigh the 7200mah? I'm using 5000mah 3S and one of those is 15.75 oz. I have said before I wish they were a tad heavier. I have yet to totally pull the throttle because the z is in the air most of the time. The best placement I have found is 2 batteries forward as far as they will go and the other 2 as far back as they will go.
                      Is the 4mm strut at parallel or did you go up or down?
                      I know in general, when things are behaving the way you want, sometimes it's best to go back to the defaults - ctrl-alt-del so to speak. Find the best placement for your batteries before you start messing with the struts. Didn't we get 2 sets of props with the boat? Or maybe I bought an extra set. You might try going back to originals. If nothing else, then you'll have some backups.
                      Stay with it!
                      Mike
                      • vinnyp
                        • Mar 2017
                        • 283
                        According to SMC's website, the 7200 MAH weigh in @ 16.47 oz. Not much more than 5000 MAH. I don't think that is my problem. The struts were @ 4mm. As I look at more You-Tube videos of these boats running, the water they are running is much flatter than what I have here. The boats in the videos are running bow high, packing air, not bouncing around at all. Don't think mine will ever be able to run like that, unless I find another place to run. I am sure the bumps are costing me considerable amounts of speed.
                        Since I attempted to work my props myself, it is totally possible that they are not right. My boat didn't come with any other props. I am trying to get a set of ABC 1814-17-45(2) from OSE. However, the left hand prop is out of stock.
                        Like the full sized boats I work on, trial and error is the only way to make performance gains. Only I have been doing that for 30 years, only messing with RC boats for 30 DAYS!!!!
                          • 4338
                          Vinny - If your water is as rough as you say it is, the 1814 props might be too aggressive, and hard on the electronics. You might try a set of x447's or even 447's cut down to 45mm. A professionally prepped set will do wonders compared to the stock 442's. Hit up Dasboata for a set.
                          • dasboata
                            • Dec 2010
                            • 3972
                            I have a set of 1814 I can race prep for you ,,,,,,,and thanks Ryan
                            • vinnyp
                              • Mar 2017
                              • 283
                              Thanks for the replies..
                              Dasboata... what do you think about running a set of 1814 in less than ideal water? If you think they would work, can you p.m. a price and an estimate of how long it would take.
                              • dasboata
                                • Dec 2010
                                • 3972
                                Do you mean ruff ?
