  • Mightynova63
    • Aug 2016
    • 37
    #1171
    Do you have a link for the cheaper one?
    Ditch the maxx amps batteries. They are overpriced garbage. They are the the weakest batteries I've ever tried, confirmed in back to back gps testing. Your paying for a warranty and very cheap under powered cells.
    so what batteries are you using?
    • Mightynova63
      • Aug 2016
      • 37
      #1172
      Originally posted by Crazykev View Post
      Damn! Your gonna run 4 at a time? I plan on running 2, but never would have thought that 4 would be OK weight wise. That's 6 pounds of battery!
      ya they are heavy but i was able to get 60mph out of a stock setup. with probably around 12min drive time, it felt like more so that may be conservative.
      https://www.youtube.com/watch?v=tZb0c9cvTsc. i think i could have picked up a little bit more with some trim work. but i was having fun instead.
        Revolectrix
        http://www.offshoreelectrics.com/pro...rod=rev-ys5000
        • Crazykev
          • Jun 2016
          • 44
          #1174
          I have run more than 10 different lipo manufacturers over the years and still run different lipos, but if I didn't notice that the Maxamp pack out performed the others by a considerable amount then why would I order another one? The 9000mah packs are SMCs and I don't think the dual motors are gonna drain more than those 60C 9A batteries can pump out without hurting them. As far as a 5A-6.5A battery goes, I know that I'll be pushing the crap out of them in the Zelos Twin, so I know for a fact that the 150C rating of the dual core packs will make a difference. After runs in my other boat, the 5A 50C battery is HOT when I pop the cover off and the 6.5A 150C battery is just warm and not even close to hot. I worry about toasting the 50C pack and don't even think twice about doing any sort of damage to my Maxamp 150C pack.
          Did you test the dual core 150C batteries? I think most people that have anything bad to say about Maxamps is going off comparisons they did years ago and have never even run one of these new generation packs. I've tested them against my SMCs and my Venom packs and they hold a higher voltage for MUCH longer! I don't want to get into a pissing match about it, but these dual core packs are flat out the *!***!***!***!**. You want the best battery on the market, then get one of their dual core packs. I can't say anything about the older versions, but if you say you've tested one of these and can't tell the difference, then your full of *!***!***!***!**. They are expensive, but if you want the best, then it's gonna cost ya. The dual core packs are the true 150C rated packs. If you are comparing any of their other packs, then I can't argue with ya because I haven't ran them. I've been running RCs for 28+ years and can tell the difference between a good quality and crap pack. I would honestly think someone had something against the company if they tried one of these 150C packs and said they couldn't tell the difference or that they have no idea what they are talking about. Are they worth twice as much as the other packs, well that depends on the person, but they are BY A LONG SHOT the best batteries I have ran in my helis, cars or boats. They don't even get nearly as hot as those 7,200 SMC packs. Just warm and not what I would consider hot. I don't work for or have anything to do with Maxamps, but in my experience they are worth it and blew the other packs out of the water :) Maybe their older 100C and 120C packs weren't what these 150C packs are, but why do I care being that I don't own one of their cheaper packs. If you did test one of their new 150C packs and considered it weak, then you got a bad pack or something, but I am sure you didn't test one of these packs, so how can you comment on it? Not being a dick, but I am sick of people commenting on something they haven't ever run. These 150C 6500 packs are freakin' beast and every person I know that runs them or has tried them feels the same way. Maybe the other cheap companies caught up with the old Maxamp batteries, but these new generation dual core packs are beast! I'd rather just move on with the fun stuff and not argue about something I see as a fact, at least for the time being until the cheap companies catch up again. Maybe for a while Maxamps got greedy and started using the same cells as everyone else? I don't have any idea, but things change and these newer 150C packs are in fact better than the cheap ones. They are better and to me they are worth it. If we were running something that is pulling 80-100 amps, then maybe they are a waste, but the Zelos Twin is asking for it's batteries to pump out probably 160-180amps. If you get a chance, run one of these new generation Maxamps dual core packs and you'll see what I'm talking about. My Blackjack 24 kinda hops out of the water with either of my two SMC 7200s or my Venow 5000, but the boat does a freakin' backflip with the Maxamps. If you want me to make a video to prove this to you, I easily can do so. I have no reason to lie about my experience and could care less if anyone buys a single Maxamps battery and am just explaining the facts about their performance that I have seen.
          I'm mistaken, my brother did run the 100C Maxamps packs 2 years ago and there wasn't a big difference between his Maxamps and the cheap ones. I can say that his Maxamps lasted TWICE as long as his cheapo packs and he in fact still runs them. His cheapo packs eventually puffed after one summer of use. If you have to buy 2 packs to equal the service life of the Maxamp battery, then do they really cost that much if any more than the cheap ones?
          After burning up 4,900mah out of my Maxamps dual core 150C 6,500mah packs, they feel like the SMC 7,200mah 3S packs after only going through 3,000mah and that isn't even half of their capacity! I can't tell much of a difference if their performance until I get really close to that 4,900mah number. I don't go much past 5,000mah with the SMC packs because they start to slack off on the voltage by then and I think that maybe the ESC already hit where cutoff is slowing it down or that it's at least close to doing so. I like the SMCs because I at least have something to run while the Maxamp is charging which doesn't take long because they are rated to be charged at 5C. The SMC 2C charge rate seems like forever compared to charging a battery at 5C. I like the SMCs and have ordered 2 more, so I'm not knocking on their performance. They just don't hang with what I consider a top of the line battery.
          Anyone that tries to make me think that the 150C packs aren't better than ANY other pack out there is just wasting their time. You can say they aren't worth it, but that is relative to your income or if you even care that they perform better. Do they perform 2X better than the cheap ones? No, but in my experience they last twice as long, have the best warranty you'll find for a lipo, have killer customer support and do in fact out perform the others. In this application I feel that they are worth it because a cheaper pack is going to fall on it's face pretty quickly if your beating on this boat. I think running 4 of these 150C packs in the Zelos would be overkill and you won't really see the difference when 4 batteries are pulling the load instead of 2.
          The other pumps are listed here:
          The blue ones on that list are $27 and flow 24gph, but from what I can tell, they are a magnetic coupled impeller and would rather run a direct drive. They spin the impeller like maybe you have seen in a lab or on TV spinning inside a glass beaker. I'm worried that they won't push the PSI needed. I'm willing to try one for the $27 cost. Maybe I am wrong about the drive, but what else would a magnetic coupler be? The screen on the front of them can be remove to expose the input fitting.
          http://www.ebay.com/itm/Submersible-...-/331085260375
            • 9481
            #1175
            Agreed !
            I've tried them and they blow
            I need to try this new blend
              Did you test the dual core 150C batteries? I've tested them against my SMCs and my Venom packs and they hold a higher voltage for MUCH longer! I don't want to get into a pissing match about it, but these dual core packs are flat out the *!***!***!***!**. You want the best battery on the market, then get one of their dual core packs. I can't say anything about the older versions, but if you say you've tested one of these and can't tell the difference, then your full of *!***!***!***!**. They are expensive, but if you want the best, then it's gonna cost ya. The dual core packs are the true 150C rated packs. If you are comparing any of their other packs, then I can't argue with ya because I haven't ran them. I've been running RCs for 28+ years and can tell the difference between a good quality and crap pack. I would honestly think someone had something against the company if they tried one of these 150C packs and said they couldn't tell the difference or that they have no idea what they are talking about. Are they worth twice as much as the other packs, well that depends on the person, but they are BY A LONG SHOT the best batteries I have ran in my helis, cars or boats. They don't even get nearly as hot as those 7,200 SMC packs. Just warm and not what I would consider hot. I don't work for or have anything to do with Maxamps, but in my experience they are worth it and blew the other packs out of the water :) Maybe their older 100C and 120C packs weren't what these 150C packs are, but why do I care being that I don't own one of their cheaper packs. If you did test one of their new 150C packs and considered it weak, then you got a bad pack or something, but I am sure you didn't test one of these packs, so how can you comment on it? Not being a dick, but I am sick of people commenting on something they haven't ever run. These 150C 6500 packs are freakin' beast and every person I know that runs them or has tried them feels the same way. Maybe the other cheap companies caught up with the old Maxamp batteries, but these new generation dual core packs are beast! I'd rather just move on with the fun stuff and not argue about something I see as a fact, at least for the time being until the cheap companies catch up again.
              The blue ones on that list are $29 and flow 24gph, but from what I can tell, they are a magnetic coupled impeller and would rather run a direct drive. They spin the impeller like maybe you have seen in a lab or on TV spinning inside a glass beaker.
              I'll put money on it that the max amps will fall short of revolectrix batteries. How bout this, I'll bet you $100 payable via pay pal. You send me a pair of 4s packs to run in my 32"cat and I'll test them on video back to back. I'll make sure and show the gps and battery voltage. The day a maxx amps battery out performs a revo battery is the day I'll call it quits in this hobby. I'll pay for shipping to me and back to you just to prove it. If you don't have a 4s pair let me know what you do have. I can test in another boat I have one way or another. I tested their true 150c packs and they were a lot slower. I posted the testing here and there's video to prove it. I ain't about no bull****
                Agreed !
                I tried them in a rigger that puffs all other batteries after 3+ minutes full throttle. The battery temp was only 98f
                They are awesome.
                • iop65
                  • Mar 2013
                  • 367
                  #1178
                  Originally posted by Yellow View Post
                  If too much water flow wouldn't absorb heat from the heat sinks, perhaps a coil of silicon cooling tubing could act as an accumulator and slow the flow of water.
                  the things one can read here !!!
                  you mean this..... really?
                  one should pay more attention during the physics classes so things like this wouldn't pop up on a forum
                  too much flow........no enough.....again..... really?
                    Some people like to over complicate things. It's just what they like to do. Me, I like simplicity. As long as you have water coming out of the outlets you'll be fine. It doesn't need to be a 2 foot stream either. As long as it's coming out and you can see it as it passes by you. You won't see it at full speed very well do you'll have to go a little slower to see it.
                    • Darin Jordan
                      • 9446
                      #1180
                      One other thing I've found is that the nipples on many of these water jackets and speed controllers have TINY openings in them. Most recently I see this on the TP water jackets. Hard to blow through them, let alone push water through them. The water jackets from OSE have proper sized ports. I've tried drilling out my TP jackets, but the thread size is so small that you are very limited in how large you can go.
                      Darin E. Jordan - Renton, WA
                        Your right and you have a very good point. I need to drill mine because in some of my stuff the tp motor runs a little warm. Good call.
                        • Darin Jordan
                          • 9446
                          #1182
                          I'm not even going to bother with the TP jackets in the future. Not enough volume internally (very close/tight fit to the can, with very little gap). For many 36mm motors, my Pro Boat/Dynamite jackets fit fine. Otherwise, I'll order the custom made OSE jackets. Solid, and price is reasonable.
                            I'll agree the tp jackets do not have much room for water. I may need to change water jackets on a couple boats I have. My mini Rivercat for one. The motor does get a little warm and I bet the jacket does have something to do with it. I just love the way the tp jackets look tho. Sometimes they are needed for clearance too. But if you have clearance then the jackets that ose and kintec sell would be far better. Glad you pointed this out. I knew better but I didn't want to come to terms with the fact that the nice looking tp jackets weren that efficient. Bummer.
                            • daHammer
                              • Apr 2016
                              • 23
                              #1184
                              Travis are you still running the 6s version of revolectix and no problems with CG?
                                Originally posted by daHammer View Post
                                Travis are you still running the 6s version of revolectix?
                                I haven't tried the 6s batteries just yet. I haven't even put the motors in the boat. I need to, I've just been busy with other stuff.
