3/8" worth of threads, no loctite just lock washer. Checked them after my runs, haven't budged. Just make sure you crank em down good.
Polishing
Polished everything up to a mirror finish, already notice a small boost in performance :) (Stock props in box)Attached Files
I am sorry if I posted things that went wrong on stock Zelos 36. I thought that's what this thread is about, not only mods to boat and out come, but to make alert of problems that can happen and how to correct it.Zelos 36 stock 68 mph
That looks real nice!Originally posted by Chris VB View PostPolished everything up to a mirror finish, already notice a small boost in performance :) (Stock props in box)Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
Yup, I cry a little inside every time I pull the trigger and boat goes nowhere. lol. I start calculating in my head, there goes another 20-30 bucks plus S&H plus 3-4hrs of S&B.Originally posted by Erroneous View PostCall it what you will but. A lil blue locktite serves me well. Dropping $50 props with tons of time in them into the unknown depths is no bueno.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
SHAFT CORRECTION.jpgwell add me to the " to much in a rush stupid list ". I ruined the stock right flex shaft do to greasing and installing wrong, as in (L) (R) expanded the cable. Wondered why I lost speed. have new shafts from ose only because they are a little longer at the threaded end so bigger props are no problem. Here is a example I made to help people that get confused on the way (L) and (R) shafts work.wrong.jpgcorrect.jpgTHIS IS INCORRECT, NEW POST SHOWS CORRECT WAYZelos 36 stock 68 mph
It also depends on what way your props are turning. Are yours setup to turn inward or outward?Originally posted by Team Lucas View Postwell add me to the " to much in a rush stupid list ". I ruined the stock right flex shaft do to greasing and installing wrong, as in (L) (R) expanded the cable. Wondered why I lost speed. have new shafts from ose only because they are a little longer at the threaded end so bigger props are no problem. Here is a example I made to help people that get confused on the way (L) and (R) shafts work.[ATTACH=CONFIG]145588[/ATTACH][ATTACH=CONFIG]145589[/ATTACH]
You da man!Originally posted by Team Lucas View Postwell add me to the " to much in a rush stupid list ". I ruined the stock right flex shaft do to greasing and installing wrong, as in (L) (R) expanded the cable. Wondered why I lost speed. have new shafts from ose only because they are a little longer at the threaded end so bigger props are no problem. Here is a example I made to help people that get confused on the way (L) and (R) shafts work.[ATTACH=CONFIG]145588[/ATTACH][ATTACH=CONFIG]145589[/ATTACH]
