  • Erroneous
    • Apr 2016
    • 451
    #256
    Instead of raising struts, try setting CG with battery position first.
    Will do. I'm pretty limited to adjustments with the ESCs in the back of batt tray. Struts are sitting 3mm from bottomed out now. The new hull flies flat and true. If these ESCs prove to be too bulky I might pull em out and swap for 200s using these in another monster. On a side note, I think my garmin 101 is lying. I ran faster than ever on Saturday and it showed 56.9. Pulled 73.3 on chop a few days before. The Saturday run was quite a bit faster, again smooth as can be but somewhat wet. Thinking about the Dynamite gps, 10hz should be a ton better.
    • Keagan-Z06
      • Mar 2016
      • 970
      #257
      Got my Forerunner 201, Octura 447? Prop Balancer & SMC 5000mah packs. Any tutorials or vids on how to sharpen and balance props? This will be my first attempt and would rather not screw it up.
        Here's a video
        • Keagan-Z06
          • Mar 2016
          • 970
          #259
          Thanks KFX!
          • ChevyPrerunner
            • Jun 2015
            • 205
            #260
            I tried out my new OSE CNC 43mm props and got 59.2 mph on 6s and stock settings. One of the props tips came clean off though not very good aluminum these are made from.
            • Yellow
              • Jan 2016
              • 81
              #261
              I wonder if you hit something in the water?
              Also... are the sock stainless props better than the CNC props if sharpened and balanced?
                I don care much for CNC props on bigger boats like this but it looks like you hit something like
                • Keagan-Z06
                  • Mar 2016
                  • 970
                  #263
                  Hey guys, I am a bit hesitant to sharpen and balance my octuras. I am really afraid of messing them up. Even after watching some videos, Im a little bit intimidated by all this. As soon as I balls up, I'll do a run.
                  • ChevyPrerunner
                    • Jun 2015
                    • 205
                    #264
                    There was nothing to hit in the water where we were running, water was clam, flat and clear. This is the 4th CNC prop that this has happened to in my club in the past month. The Aluminum has cavities in it meaning the metal is not a pure batch. If you sharpen and Balance the stock props really well I'm sure they would be stronger but not as light as the aluminum Cnc props.
                    All is good, will get some Octura 45mm on this baby and see how she does.
                    Cheers!
                    Brian
                    • Yellow
                      • Jan 2016
                      • 81
                      #265
                      That's crazy how they broke like that. Thanks for the heads up.
                      • Erroneous
                        • Apr 2016
                        • 451
                        #266
                        I'm no pro and I'm sure someone will slam me for this but.... You gotta think, you're putting nearly 3/4hp down on something potato chip thin pushing 10lbs through the water at ballistic speeds..I can't speak for other props. I can however vouch for the Octura x442s, 447s and the ABC props. All have a totally different attitude though.
                        • iop65
                          • Mar 2013
                          • 367
                          #267
                          get some tenshock cnc's
                          • iop65
                            • Mar 2013
                            • 367
                            #268
                            get some Tenshock cnc's
                            • Keagan-Z06
                              • Mar 2016
                              • 970
                              #269
                              So I finally manage to get my replacement ESC for the twin, is it plug and play or does it need to be program and all that?
                              • shua
                                • Apr 2015
                                • 479
                                #270
                                Did you get it directly from Horizon Hobby?
                                If so it is plug-and-play but it probably would be a good idea to calibrate the radio throttle to it
