I've got a set of 1814-17's to try out as well. I'm good with 70mph, but would be interested to see how the ABC's change the ride vs. the x447's I ran last season.
For the ABC 17 degree rake props, you have to set your drives down about 2 degrees.
That is the rear or prop end down.
This is done because these props have so much push, if you leave your drives level, they will lift your bow too much, and moving enough weight forward to compensate will upset the balance of the hull.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
They were 1915-17 but Dasboata made them to 1815-17 with less pitch. What were you thinking?Originally posted by TRUCKPULL View Post1815 's have more pitch the 447's
1.8" = 45.72mm x 1.5 = 68.58mm pitch
47mm X 1.4 = 65.8mm Pitch
Your 1815's are they the 17 degree rake props??
1815-17-45/2
LarryProboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
Winter session report
Temperatures went a little up so i went to the lake after 3 months stop!
LVC:
last time, after 3'30" running, right ESC red led was blinking...
so i checked LVS setting: both ESC at 3.2V
this time, with 2 fresh lipos (same model Nanotech 65C 5A), same run time, at the end left ESC red led was blinking.......
so my conclusion is: this lipos are good but not enough to fit the high amp drawning using 2 only lipos, so voltage difference between no load and max load is huge and hit the lvc.
Do you agree?
Can i set LVC at 3V/cell??
LiPo and top speed:
with 2 fresh LiPos the top speed is really increased!!! but i forgot my Garmin at home... next time i will log the top speed!
Anyway LiPo quality and LiPo age is really really important!
What's the best way to fit 4 batteries? i think it's impossible to add a strap to block the front lipos under the hull... i'd like to put the 4 LiPos in the same line in the middle but i don't know how...
Pictures:
While i was running my Zelos a professional photographer was going around and stop to make some shoots of my Zelos! enjoy...
ProBoat Zelos36 proshoot_01.jpgProBoat Zelos36 proshoot_02.jpgProBoat Zelos36 proshoot_04.jpg
ProBoat Zelos36 proshoot_05.jpgProBoat Zelos36 proshoot_07.jpgHPR 115 kevlar bulletproof @90mph, MHZ Rapid carbonfiber, Bingo Race Minieco
Very nice pictures! Remember if you wanna record your top speed with any setup there is a Zelos fast thread, I can't remember off hand if your on it? I'll be heading out today again. Funny you should mention positioning 4 packs. I just prepared the Zelos to use 4 3S packs vs 2 6s packs. I'll figure it out at the lake, I remember using some foam to kinda Kee the front packs snug and use only 1 strap on the. While the 2 back ones were using 2 straps each.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
The photos are all the money!!!Originally posted by banixj View PostTemperatures went a little up so i went to the lake after 3 months stop!
LVC:
Do you agree?
LiPo and top speed:
Pictures:
[ATTACH=CONFIG]149803[/ATTACH][ATTACH=CONFIG]149804[/ATTACH][ATTACH=CONFIG]149805[/ATTACH]
[ATTACH=CONFIG]149806[/ATTACH][ATTACH=CONFIG]149807[/ATTACH]Genesis 36", Zelos Twin 36"
my record on fast thread was 101kmh/63mph, i'm sure i will improve it so soon!Originally posted by Keagan-Z06 View PostVery nice pictures! Remember if you wanna record your top speed with any setup there is a Zelos fast thread, I can't remember off hand if your on it? I'll be heading out today again. Funny you should mention positioning 4 packs. I just prepared the Zelos to use 4 3S packs vs 2 6s packs. I'll figure it out at the lake, I remember using some foam to kinda Kee the front packs snug and use only 1 strap on the. While the 2 back ones were using 2 straps each.
please share a pic of your 4 lipo fitting soon!HPR 115 kevlar bulletproof @90mph, MHZ Rapid carbonfiber, Bingo Race Minieco
Yeah I'm surprised. That puts me .1mph above Erroneous and behind Rafael on the fast list.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
That is crazy! I couldn't believe it. Will upload video later of run.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
3.5minutes is about right for run time on 2 3s batteries getting drawn all the way down to LVC. If you're not timing the run itself, you're going to hit LVC on at least one of the ESC's for sure. I don't think anything is wrong with what you're seeing. Did you measure the voltage of the cells after the run to determin how much capacity was left in them?Originally posted by banixj View Postlast time, after 3'30" running, right ESC red led was blinking...
so my conclusion is: this lipos are good but not enough to fit the high amp drawning using 2 only lipos, so voltage difference between no load and max load is huge and hit the lvc.Vac-U-Tug Jr (13mph)
