    • 4338
    #1981
    Originally posted by Erroneous View Post
    In the third pic to the right of the stuffing tube you can see factory glass that didnt get wetted in. I plan on layering over this too on both sides. Along BOTH sides on the seam towards the bow there was a strip of matt just hanging loose as well. I made sure they got plugged full too.
    While you have it all blown apart, reinforce the electronics tray mounting tabs. The factory adhesive is definitely a weak.
    • MADRCER
      • Feb 2017
      • 765
      #1982
      I saw this over the weekend at a line-x dealer in Knoxville and thought I would share. Reinforcing the outside instead of the inside....You wouldn't have to worry about sanding/scuffing the ride pads with that on!
        • 4338
        #1983
        Looks heavy
        • REDLINE1
          • 199
          #1984
          [ATTACH=CONFIG]152130[/ATTACH]
          WTF! Don't think that's gonna make the top 5 Zelos fast list lol
          • Team Lucas
            • May 2016
            • 300
            #1985
            Gave me a idea. I also build gas wood boats. I use www.klasskote.com for paint. Spray the boat with epoxy clear. Nothing will crack or leak...it's epoxy.
            Zelos 36 stock 68 mph
            • REDLINE1
              • 199
              #1986
              That stuff looks nice! Good idea
              • Team Lucas
                • May 2016
                • 300
                #1987
                TY.
                • TRUCKPULL
                  • 3293
                  #1988
                  I had Line-X in my truck bed, it is 1/8" thick and NOT light.
                  Finish is too coarse for what we need.
                  Larry
                  • Erroneous
                    • Apr 2016
                    • 451
                    #1989
                    In other news. The line-x is good for coating the inside of speaker boxes. Its good for about 2db vs non coated.
                    • Mxkid261
                      • Jun 2015
                      • 734
                      #1990
                      I also have it in my truck bed and lower 1/3 of the body/bed is lined too. Awesome stuff but definitely not for an r/c boat Lol
                      • banixj
                        • May 2012
                        • 110
                        #1991
                        Today hd flex from Jeff are arrived but one of two is not perfect: there's an angle in the juncion between flex and shaft... that's why it doesn't roll on a table...
                        Could it be a problem for vibrations or strut?
                        I need an opinion...
                          It's going to vibrate andwear the strut out if it's not straight. When I make my flexes I put them in an aluminum jig I matched from a block of aluminum that clamps them perfectly straight so there's no vibration. Maybe these just slipped past him. He's been known to make high quality stuff.
                            • 4338
                            #1993
                            I would not run it. One of my stock cables was not aligned perfectly and it wore out the strut bushings quickly.
                            • Team Lucas
                              • May 2016
                              • 300
                              #1994
                              use to roll it on a flat, and if it wobbled, its bad
                              • stratus
                                • Dec 2016
                                • 110
                                #1995
                                Like the others said don't use it,contact him and ask to be replaced.I am using the ones from OSE and they are perfect!!
                                Genesis 36", Zelos Twin 36"
