Originally posted by Boaterguy1000
View Post
I have found its easier to remove the mount with motor intact, then swap motors and reinstall the mountZelos 36 stock 68 mph
Got a chance to run my Wohlt wire drives for the first full run today. I put them in last fall and never got a chance to really get a good run because I was having esc problems. Ran good today got 67 mph w 4 battery's wire drives worked well after about a 10min run mostly speed runs back and forth with some slower cruising in between. Zero water leaking it. I did remove the struts and remount with silicone sealer before installing the wire drives but I'm not using any cap seal on the stuffing tube up by the motor.
Other thing which I don't know if will be an issue with extended use is when I install them I have to use a hook to lift the wire slightly up to get it to go into collet So because there is a slight end in the wire when installed there is some downward pressure on the collet end of the motor shaft
Today i'm so happy! Thanks to brand new 6S lipos! My personal record is now increased!
MPH: 69 (good number) but real is 68.75....
Prop: TFL CNC 4714
ESC: Stock with timing 7.5
Motor: Stock
Batteries: 2x Zippy Compact 3300mAh 6s 60C
Mods: Polished shafts
Temps:
Air: 21C 70F
ESC: 45C 113F
Motors: 50C 122F
Next step: ABC 1715 prepped by an italian guru then HD shafts!
My target is 75mph! i hope to don't fry all during summer....HPR 115 kevlar bulletproof @90mph, MHZ Rapid carbonfiber, Bingo Race Minieco
Nice man!
Batteries match the boat :).NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Hope you break the 75 soon :) btw what run time you got with those 3300 mah?Originally posted by banixj View Post[ATTACH=CONFIG]150832[/ATTACH]
Prop: TFL CNC 4714
Motor: Stock
Temps:
Air: 21C 70F
ESC: 45C 113F
Motors: 50C 122F
My target is 75mph! i hope to don't fry all during summer....Genesis 36", Zelos Twin 36"
Have a question w/o going back pages.....I been seeing in list, some have polished shafts. How do you polish a flex shaft?Zelos 36 stock 68 mph
i can describe my way to do it: synpol cream and dremel with felt cap on it...
oxide come out, specially where there's ontact with bearing sor others...
obviously this treatment must be done on the "not flex part" of the axle...
i use synpol cream with paper too on my mini eco rigid wire shaft...HPR 115 kevlar bulletproof @90mph, MHZ Rapid carbonfiber, Bingo Race Minieco
I polished the shafts on my wire and cable drives. Use a power / cordless drill, chuck the motor end of the cable or wire . Take a piece of fine emry folded between your fingers put a little oil on the shaft start the drill while holding the shaft between your fingers with the emry. Then I go back over with a soft cloth with mothers or flitz polish and drill looks like a mirror when doneOriginally posted by Team Lucas View PostHave a question w/o going back pages.....I been seeing in list, some have polished shafts. How do you polish a flex shaft?
I put the flex cable in a drill and spin the entire thing while polishing the flex cable with sandpaper. I can't remember if I used 400 or 800 grit wet/dry. I know where it is in the drawer anyways.
I use Mother's metal polish on the prop shaft portion with a soft rag.Vac-U-Tug Jr (13mph)
See, I knew I did mine wrong. I put some valve grinding compound on the flex, then ran it back and forth in the stuffing tube about 1 1/2" with the drill on full speed. Then cleaned everything and repeated the process with Flitz polish. Spins good, still hear the scratchy sound though while spinning it. I might have to get a can of brake cleaner.
Same here. Flexxes in a drill but I started with a 3m 320 grit then 600 then 2"x2" polishing pads from Amazon. Carefull with the foam polishing pads if you use them. Too much pressure or too fast on the drill they will start to melt. Shafts are nice and shiny. Heres the pads. https://www.amazon.com/gp/aw/d/B00B3...?ie=UTF8&psc=1
