Originally posted by GMMWicked
View Post
Bought a ProBoat Stealthwake to play with
Are you still running with the stock solid prop shaft? Just curious because I finally upgraded to a flex shaft and strut and I'm having issues with handling. The boat ran fast and predictably even with the negative prop angle with the stock solid prop shaft. But now that I have the prop "level" it's been a challenge to tame it and I'm still working on it.
I just upgraded to 90 amp turnigy esc and surpass 3300kv motor, running 2s. Now this boat is rockin. Love it. The brushed setup is horrible and overheats so quickly. Best upgrade I?ve ever made.
Leave a comment:
I know this question is pretty old, but for anyone else looking to do the same thing I can tell you that we are still running the stock rigid driveshaft on the Stealthwake. The boat has a 2600KV brushless motor and so far it's only been run on 2S. It has a few other upgrades like trim tabs, but even with the stock 1.6x1.6 plastic prop, it runs great and runs around 25mph. We haven't tried a 3S yet, but I'm sure it could handle it. We do have plans to upgrade to a flex shaft along with other upgrades for the 2021 season, but for the past 2 years with the brushless and rigid shaft, it's been a great boat in all water conditions! See the videos link in my 'signature' to see how it runs.Originally posted by Davey80 View PostHow important would you say it is to swap the direct drive over to a flex shaft? If i'm sticking to 2-3S and around 30mph, do you feel the stock driveshaft is up to the task or would there be some diminished performance with the negative strut/prop angle?
Thanks, Mark D.
Leave a comment:
Actually, Offshore Electrics sells a coupler that will meet your needs. I was just looking at it today! Just go to their page and search for the "OSE Aluminum coupler." I assume they actually make it because you can get it in just about any size you need. I looked at the "5mm motor" one since it's 5mm on the one side and for the Stealthwake, you'll probably need the 5mm to .130" It's a rigid coupler. Of course, you can get universal joint couplers as well, but if you use the same mounting plate and can get the motor back dead-in-line, the OSE rigid coupler is your best bet.Originally posted by telcoboy69 View PostA 3mm to 5mm rigid coupler?
Leave a comment:
I am using a Racent 40A esc that came out of my Volantex (Racent) Atomic. I have a Dynamite 4 pole 2000kv motor. The combination seems to work well on 3s.
Leave a comment:
What esc are you using???Originally posted by telcoboy69 View PostMaybe this question has already been answered but I am trying to convert my Stealthwake to brushless. I would like to run 2s-3s in it. I have a Dynamite 2000KV motor with a cooling jacket (DYNM3900). The motor has a 5mm output shaft. I'm not replacing the stock driveshaft. Which coupler should I use for this application?
Leave a comment:
@telcoboy69
I'm in the same boat (LOL
I might do a flexshaft upgrade still but will first give the stock driveshaft a go. The day I bought it I ran it ONCE, concluded it was too slow for my liking and proceeded to rip out the stock driveline/electronics.
I'll put a 3660 3180kv (2s MAX I think hehe) marine 4 pole motor in it. (had it in my traxxas blast for a little while running 6 cell nimh). The blast driveshaft and even the nylon U-joint (not the plastic motor/driveshaft coupler, it's trash) can take it. Keep in mind that the blasts driveshaft is roughly 3/4 of the length of the stealthwake shaft and 4mm opposed to the SW's 3mm. Traxxas really should sell it with such a setup as stock, that way it actually lives up to its name hahaha.
Funny enough the stuff I pulled out of the stealthwake will find it's way into the Traxxas blast and it will be used as a rescue rig.
To reply to your question... I will also be using a 3mm to 5mm rigid shaft coupler. The problem with that (for me at least) is that I wasn't able to find one for some time until I turned to Aliexpress and Banggood. Strange that no LHS or even webshops seem to offer a coupler with those 2 dimensions. I don't know it might be a different story in the States. YMMV.Last edited by KL0J0; 08-04-2019, 05:51 PM.
Leave a comment:
Leave a comment:
If you don't want to crack the hull, simply open the dimater of the hole in the transom ever so slightly so that the new stuffing tube doesn't split anything open. You need to cover the entry point on the inside of the hull with epoxy anyways, so a little increased tolerance won't hurt anything.
The Shockwave strut doesn't really do much for this application because it sits so close to the transom and the stuffing tube runs all the way through the strut itself. There would be no vertical or trim angle adjustment. The Recoil 26 strut at least has a bushing in it, which would allow you a small amount of adjustment if there was a little slop in the fitment between your new stuffing tube and the strut body. I used an adjustable stinger when I replaced my solid shaft with a flex cable. I cut the new brass stuffing tube flush with the rear of the hull (through a new, higher hole in the transom) and ran a longer teflon liner out past the transom and into the stinger. This gave me all of the vertical trim adjustment I needed because the teflon liner can flex outside of the hull.
Leave a comment:
No, I never tried the shockwave strut. It might work though. There is another in depth stealthwake build on this forum. You should see what he used because I believe he did install a strut.
Leave a comment:
Hey just wondering if you tried to use the sturut from a shockwave 26 along with the tube and flex shaft. I’m trying to go flex shaft but not sure if it will work I really want to avoid cracking my hull😬
Leave a comment:
You're correct, I didn't add a strut. The intent was to test it and then add one later but I never seemed to need one to support the stuffing tube. The stuffing tube never moved so I didn't add a strut. I would recommend not having a super tight fit between the stuffing tube and the hull. Mine was very tight and it caused a hull split. So make it a snug fit and then secure it inside with epoxy. I'm not saying my methods were the best way to build a Stealthwake, it's just how I did it and wanted to share.
Leave a comment:
Originally posted by arrover View PostI only ran the stock drive system with the stock motor. I changed to the flex shaft and the brushless motor at the same time so I can't comment from experience. It seems to me that the stock prop angle will continue to force the bow down harder as you put more power into it. It might not handle well but I can't say for sure. Rafael also recommended getting the prop level.
Rgr, thanks. So it didn't look in the picture like a strut was added when you switched over to the flex cable. Just want to make sure I got that correct. Is the tight fitment of the 9/32 tubing through the ABS hull enough support when running brushless?
Mark
Leave a comment:
Leave a comment:
Leave a comment:
