PB BlackJack 29
  • lomdel
    • 722
    Originally posted by Diesel6401 View Post
    I would go 4s or 5s for short burst. 5s2p would be a lot of weight in that hull. I would say 2s 5000mah 30c or 40c with matching 3s 5000 30 or 40c packs. Give you 4s and 5s combos... just me.
    6s no comment...
    Sent from my T-Mobile G2 using Tapatalk 2
    A 2S and 3S combo for 5S total would be uneven weight distribution, or how would you mount them...? I hear the weight argument of 5S2P. Should reconsider that then. First try 2x 2S in serie and if the speed is sufficient, stay there, otherwise try something for 5S. Putting in a different prop and a 180A ESC would enable 2x 3S for 6S for sure! Now we're talking...
    • Diesel6401
      Memento Vivere
      • 4391
      3s on the port side. The boat is going to neutrally want to lift that side out of the water due to torque roll. I ran 5s like that in my MG, no issues... same hull!
      If you go 5s2p your going to want and prob need to remove the battery trays to get the weight low in the hull.
      Weight CAN be your friend, depends on the application though.
      - Diesel's Youtube
      - Diesel's Fleet
        Just showing my version of the BJ29, Really liked the font but, wanted my own style.
        Canopy done, needs a second/third clear on main hull and some decals.
        Letters & arrow all paint. Molotow Premium rattle can. no drips no dust gauranteed. Funky paint but, it works.
        • wpshen
          • 2
          i just checked the proboat website . they change the release date to early October . i have been waiting for this boat for a long time , have to wait again ? what happen proboat ?
          • Tom899
            • 91
            #35
            Summer will be over here in Michigan when these are finally available so not sure if I should write this year off. Is there another boat I should be looking at? Maybe a AuquaCraft Revolt 30?
            • lsguy
              • 2
              #36
              hi im new to this forum i have a blackjack 26ss bought it about a year ago and love it i have removed battery trays and tupperware lowered esc thrust bearing on the motor modified fins i also pulled motor apart and put ceramic bearings in it with a prather s220 and 2 3 cell 65c thunder powers i hit 56 mph on gps i have made about 20 runs with this setup and no fire yet the motor and esc get warm but not hot at all im looking at the new bj29 what speeds are you thinking on 6 cell sorry for the long first post just wanted to let you know what i have
              • lsguy
                • 2
                #37
                how fast are you thinking the bj29 will on 6 cell
                • lomdel
                  • 722
                  #38
                  You'll fry the stock 1800kv motor on 6S except for a SAW pass. Try to keep the theoretical rpm range just below or on 30k ... She will be plenty fast on 6S but won't last long!
                  • arp1500
                    • 146
                    #39
                    the proboat web site says 2s or 3s lipo
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      #40
                      Doesn't matter if it can take not or not. Just because it can handle the voltage doesn't mean the components and drive train will handle the amp spikes and the increase in rpms. Just ask the traxxas spartan guys about how well 6s worked for them in a 1800kv rtr. No place for 6s in a rtr boat and I've been active in voicing my discontent but I'm a nobody in this hobby so new guys will burn on 6s and come here and complain. Way of the world. They really should have went with the pb1500 kv motor. That on 6s gets a Diesel seal of approval!
                      Samsung Galaxy III via Tapatalk
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • stadiumyamaha
                        • 1371
                        #41
                        Not to mention with the right setup you can get that hull in to the 50s pretty easily on 4s2p. Just a motor swap away.
                        6s= time bomb with stock gear.
                        • ruffdawg
                          • Apr 2012
                          • 59
                          #42
                          I only need enough battery time to mill and run 6 laps so im looking for good power and maybe 5 mins run tome, i was thinking of 50c 2s ? can i go with more c on this boat and what mah would you guys run just for racing... thanks
                          • lomdel
                            • 722
                            #43
                            Any inside news on the release date, Darin?
                            • gyrotron
                              • 499
                              #44
                              Darin,
                              Will PB come up with an ARTR version of the BJ 29 w/o transmitter and receiver?
                              • Darin Jordan
                                • 9446
                                #45
                                Originally posted by gyrotron View Post
                                Darin,
                                Sorry, Guys... I'm not really deeply into the loop on this one. Not sure what the delivery schedule is.
                                As for the ARTR version... I will ask.
                                Darin E. Jordan - Renton, WA
