what is the cell limit on sv27 esc
  • pugman2
    • 241
    can i safetly run 2- 7 cell packs without toasting the esc? dont have any cooling issues whatsoever with props and motor now running hills ib 6 cell pacs would like to run 2 ib 4200 7cell packs
  • Ocean Racer
    • 511
    from what ive heard you are fine but wait for some more advise to come along to ethier prove or disprove this.
    Failure is the First step to SUCCESS
    • H&MWill
      • 680
      Yes 2 7 cells are fine but do away with BEC and run a seperate receiver pack.
      Many issues!!!
      • hex-dj
        • 240
        pugman 2... you can have 14 cells,but with a trick you can have 16 or 18 cells...with bec battery of course.
        • H&MWill
          • 680
          As long as a couple of those cells are toast.
          Many issues!!!
          • hex-dj
            • 240
            (H&M) I agree...
            • kssi
              • 45
              i run 16 with out any problems, on its own reciver pack though
              DF 22 HYDRO
              • ETOWNE
                • Mar 2008
                • 299
                16 MPH that is.....lol
                Vortex 22 hydro ammo 36-50
                Vortex Cyber Storm 33 P spec Mono AC 36-56
                PT SS-45 Q-hydro Neu 1527/1Y
                • hex-dj
                  • 240
                  Maybe he will do much better if he runs unparallel cell packs and unmatched cells,so that boat can be fully raceable...LOL
                  • Apples1
                    • Dec 2007
                    • 418
                    is that how it works , 1 cell per 1 MPH, thats an easy fix to hit 60.
                    i reckon i have 80 or so cells lying around lol
                    returning to boats after a big break
                    • pugman2
                      • 241
                      so i just plug a rec pack and switch in . and it overrides the other sorce ? or do i have to cut some wires
                      • ghostofpf1
                        • 399
                        Don't cut wires...two ways I do this
                        1) simply remove the esc's red wire socket from the plug and fold it back onto the wires and tape/heat shrink it in place
                        2) make an extension up that has the same thing done to it or has had the red wire cut off.that way you're not messing with the esc's plug
                        I've included a couple pics in case my words weren't clear enough
                        HTH
                        Ghost
                        • cuzican
                          • 4
                          If you don't mind me asking, why do you disconnect the BEC? I have been running 14 cells in my supervee without unhooking the BEC. Am I gonna ruin something or is that just a personal preference??
                          thanks
                          • kssi
                            • 45
                            thanks
                            mine started glitching
                            DF 22 HYDRO
                            • SweetAccord
                              Speed Passion
                              • 1322
                              thanks
                              The BEC inside a ESC can only regulate so much voltage that is connected by a battery by design. When you conntect more voltage than it can handle, it's not capable anymore, so glitching, heating, etc occur. So, you disconnect the red wire to not get this voltage and supply the ESC with voltage it can handle, hence the seperate battery pack.
                              Hope that clarifies.
                              Peace~
