quick noobie lipo question
  • markymizzle
    • Mar 2008
    • 14
    Is there a low voltage cut off for a stock supervee? or is this something I would have to buy if i want to run lipos?
  • all in
    • 31
    The SV does not have a cut off. I posted this same question awhile ago. Here is the easiest way. Get a Novak 4s lipo cut off(because of 2s in series is 4s). It cost me $25. Wire it in and be good to go.
    • dogsteve
      • 2
      I have two Lipo 6000HV 2S2P 7.4V Pack and two Lipo 3000HV 2S 7.4V Pack both from MaxAmps.
      What cut off should I get and where should I solder the cutoff?
      Thanks for your help,
      dogsteve
      • all in
        • 31
        just strip back some wire on the positive and negative, then solder the ends to the wire. Its only is ment to monitor voltage not carry that voltage. Then plugs inline with the servo to cut power.
        • Cartwheels
          • 4
          Novak makes one. It is called smart stop. If you are runing those in a series then you would need one for 4 cells.
          • ghostofpf1
            • 399
            Dimension engineering offers one that takes up to 12s lipos and has a 3v per cell soft cutoff but...I'm not sure if it's compatible with pistol tx as it says "only compatible with 0-100% throttle one way....car version soon " .....dunno...I just ordered one to find out.
            HTH
            Ghost
            • Cartwheels
              • 4
              HTH
              Ghost
              I believe that one will throw you into full reverse when it kicks because it is meant for an airplane. The car version, I think I heard they had quit working on. Most newer ESC have a LVC incorparated.
              • SweetAccord
                Speed Passion
                • Oct 2007
                • 1322
                Ok, so what kind of voltage cutoff and setting is needed if going to run two 2s1p packs (7.4v on each pack)?
                Thank you.
                • ghostofpf1
                  • 399
                  Newp..I have one on my sv27 on 4s and it slows to a crawl when it kicks in
                  HTH
                  Ghost
