Is there a low voltage cut off for a stock supervee? or is this something I would have to buy if i want to run lipos?
quick noobie lipo question
Tags: None
Novak makes one. It is called smart stop. If you are runing those in a series then you would need one for 4 cells.
Dimension engineering offers one that takes up to 12s lipos and has a 3v per cell soft cutoff but...I'm not sure if it's compatible with pistol tx as it says "only compatible with 0-100% throttle one way....car version soon " .....dunno...I just ordered one to find out.
HTH
Ghost
I believe that one will throw you into full reverse when it kicks because it is meant for an airplane. The car version, I think I heard they had quit working on. Most newer ESC have a LVC incorparated.Originally posted by ghostofpf1 View PostDimension engineering offers one that takes up to 12s lipos and has a 3v per cell soft cutoff but...I'm not sure if it's compatible with pistol tx as it says "only compatible with 0-100% throttle one way....car version soon " .....dunno...I just ordered one to find out.
HTH
Ghost
Ok, so what kind of voltage cutoff and setting is needed if going to run two 2s1p packs (7.4v on each pack)?
Thank you.
Newp..I have one on my sv27 on 4s and it slows to a crawl when it kicks inOriginally posted by Cartwheels View PostI believe that one will throw you into full reverse when it kicks because it is meant for an airplane. The car version, I think I heard they had quit working on. Most newer ESC have a LVC incorparated.
HTH
Ghost
