sv27 my first run...few q's
  • Goonboy2
    What me worry?
    • Aug 2011
    • 35
    Thanks for the advice on CG settings. Can you translate 27% and30% into millimeters or inches from the transom? Thanks.
    Hammer rescue boat on 2S, Supervee on 4S, Rico 31 under construction on 6S
    HO train on DC power, Nirvana II on wind power, antique phonographs on wind-up power
    • leeuk
      • Jul 2011
      • 56
      well ive ordered a new cooling jacket and 2 new props,a cf42 and cf45 so shud have plenty of fun with these.
      i have a question tho,do props wear down from normal use? i know full size boat props suffer wear but do the same things happen with rc versions?
      UK newbie to FE boats....go easy on me
      • Goonboy2
        What me worry?
        • Aug 2011
        • 35
        Yes, they do wear but they will chip, bend or break first. But be glad they do, better to break a prop than a transom.
        • Goonboy2
          What me worry?
          • Aug 2011
          • 35
          siberianhusky,
          Just did the math on the center of gravity question. Figuring the total length of the SV at 686mm (27") - 27% would be 185mm or 18.5cm or 7.3" from the transom AND 30% would be 206mm or 20.6cm or 8.1" from the transom. How does this match up to your positions?
          Goonboy2
          • siberianhusky
            • Dec 2009
            • 2206
            I have 2 marks at 7 and 8", depending on water I'm between these two points, farther forward if it's rough, right back if it's mirror smooth.
            Rudder tucked in tight to the transom, stinger at 0 degrees to the keel and trim tabs all the way up.
            The carbon props are great for testing but don't last, just last weekend a kid had the entire carbon prop explode during a run, no hub, nothing left on the shaft!
            Figure out which one you like then get a metal one.
            Each boat is a little different, we have 4 around here that run regularly and all of them seem to need a little bit different setup. The only difference should be colour, sometimes we even end up running the same size and brand of battery yet there are still slight differences.
            • Goonboy2
              What me worry?
              • Aug 2011
              • 35
              siberianhusky,
              Please clarify
              Are you suggesting that we pull the rudder in as far as it will come - like 85 degrees?
              Are you suggesting that the trim tabs be bent up or stay level with the bottom of the hull?
              Haven't tried your Octura 440/3 yet, that will be my next prop.
              SV27, UL1 motor, HK-180 ESC, Grim Racer 42-55, 2x2S25C-4000mah (soon to be 2x2S45C-5000mah)
              • siberianhusky
                • Dec 2009
                • 2206
                Yep pivot the rudder so the bottom is as close to the transom as possible, helps keep the nose planted in the turns. Not sure of the angle, never measured as it's as far as it can go.
                My tabs are as high as they will go without bending them, the screw on the adjusters is just touching the tab to keep it from flexing.
                turnfin straight up and down looking from the side. I don't have a turnfin on the port side, no need for me, I only make right turns around a course (real or imaginary depends if we feel like putting out the bouys). Late in the year we have some weed problems in out pond so anything that hangs down is a potential weed collector as well.
                Sharpen both the rudder and the beveled side of the turn fin until they are knife sharp, the blunt factory edge is awful!
                • Goonboy2
                  What me worry?
                  • Aug 2011
                  • 35
                  Roger that. Turn fins and rudder and prop are razor sharp.
                  Currently I have turn fins at 90 degrees.
                  Have you ever tried the turn fin(s) in another position like 135 degrees or 180 (horizontal) or even more disengaged like 200 or 220 degrees?
                  • makin' waves
                    • Jun 2011
                    • 92
                    I tried the rudder tucked under and didin't enjoy my boat as much, kind of like the boat skipping round the corners, and i'm not racing
                    its just for fun!
                    • makin' waves
                      • Jun 2011
                      • 92
                      Originally posted by leeuk View Post
                      heres the link to a video my friend made for me of my sv27
                      http://www.youtube.com/watch?v=9fyzM...layer_embedded
                      Your boat looks like its going well mate! get another prop and it'll be even better... for sure!
                      • leeuk
                        • Jul 2011
                        • 56
                        Ive got a cf40 2 blade to replace the stock one and a cf42 &45 on way from ose so cant wait to give those a try!
                        • Brian711
                          • Aug 2012
                          • 3
                          Turning Radius
                          I'm going to continue to post in this thread as I just bought a Supervee 27 (not the R) and am VERY new to FE boating as well. Here's hoping the thread isn't dead.
                          I got my Supervee Thursday, took it out for a spin and was VERY disappointed with the turning radius. leeuk posted a you tube video earlier in the thread (http://www.youtube.com/watch?v=9fyzM...layer_embedded) and I would have to say my turning radius is about 1/4 of his. When turning my boat with the remote the rudder only turns about half as much as you could turn it by manually moving it. Has anyone had similar issues? Am I doing something wrong, or do I have a wrong setting? The trim on the remote is set to even so I am at a loss. Any thoughts would be greatly appreciated.
                          Thanks
                          Brian
                          • Diesel6401
                            Memento Vivere
                            • 4391
                            Did you adjust the d/r? On the tactic radio its to the right of the throttle and steering trim on the old fm radio its on the top by the antenna.
                            Samsung Galaxy III via Tapatalk
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • Brian711
                              • Aug 2012
                              • 3
                              D/R, Turning Radius
                              Thanks. The manual didn't state what D/R was, and when I was originally messing around, I assumed it meant "Drive" and "Reverse" but since I heard the Supervee didn't have a reverse, I just left it. Out of water the rudder turns much more now. Can't wait to test it out. Thanks Diesel!
                              • Goonboy2
                                What me worry?
                                • Aug 2011
                                • 35
                                Also, you might try these:
                                Take the connecting rod loose from the rudder and make sure everything moves with minimal force.
                                Move the pivot at the rudder to the outside hole.
                                Install a longer servo horn.
                                Adjust turn fins to less than 90 degrees down.
