sv27 my first run...few q's
  • leeuk
    • Jul 2011
    • 56
    hey guys,you may of seen my earlier posts saying i got myself a used sv27 from ebay...well today i finally got her wet!
    altho was nice to have a go of my first fe boat,i couldnt help thinking it wasnt running 100%...
    i am totally new to fe boats and maybe im just being picky but i felt the boat had a few probs which were..
    boat didnt like turning left until on a plane..
    also the boat took about 3-4 seconds at full throttle before it would get onto a plane and really seemed to drag its ass in the water
    spec as follows..
    sv27
    stock motor
    stock prop
    60amp seaking esc
    trim tabs set neutral
    both turn fins
    strut angle is neutral
    things i tried....
    adjusted the D/R to try to get more left turn at lower speed,also tried altering the buckle that attaches to the rudder,neither really helped
    couldnt really get it to plane any better,i tried moving the lipos back and forward an inch but no help,from what ive read most experienced sv27 users tend to say just adjust the COG rather than altering trim tabs and stinger angle,i do have a CF40 prop to try as ive heard its the same size as the stock prop but being a 2 blade will help get on plane better/faster,is this right?
    will try get some pics and vids up which my help you guys understand what im trying to say,but any comments would be great
    thanks for reading
    UK newbie to FE boats....go easy on me
  • leeuk
    • Jul 2011
    • 56
    heres the link to a video my friend made for me of my sv27
    • Duster19
      • Sep 2011
      • 66
      Cool video... and I look forward to watching our builds.
      I'm no PRO, but my boat running 6 cell Ni-mhs and an aftermarket prop Octura 440/3 got to plane much faster. I would go in that direction first.
      Dave
      • Diesel6401
        Memento Vivere
        • 4391
        The slow to plane is normal with the stock prop. If you don't want to buy a metal prop and do the sharping and balancing grab yourself a CF42 and CF45 from here at OSE. Good quick upgrade over the stock prop. If you want a good metal prop grab a grim 42x55 make sure you sharpen and balance it or buy it sharpened and balanced. The CF props are a good quick and cheap upgrade over the stock.
        http://www.offshoreelectrics.com/pro...t=Carbon+Props
        http://www.offshoreelectrics.com/pro...od=dh-aqub9725 don't run this as is.. Make sure you get it S&B.
        Old SV vids
        - Diesel's Youtube
        - Diesel's Fleet
        • leeuk
          • Jul 2011
          • 56
          im glad you've sed that about stock prop as thats what i thought first,i know its def not my lipos not giving enough power as there brand new,fully balanced 30-40c 5000mah ones so plenty there,was really happy temps wise as both the esc and lipos didnt go much warmer than body temperature,altho the motor did get a little warm it wasnt dangerously but im gona look into getting the upgraded water jacket from either ose or kintec and file out the rudder pick up just to help cooling as i cudnt really see any water coming from the outlet when running.
          Diesel,is the cf40 still ok over stock as ive seen people mention the cf42 and 45 more often than the cf40,and are these both ok on stock motor?
          im running the seaking 60 esc and im quite impresed with it so far,easy to program with program card and a good fairly cheap upgrade over stock esc with little more scope on ampage draw so i felt safer in the water.
          Duster,how you getting on with your build buddy?
          • Diesel6401
            Memento Vivere
            • 4391
            Yea the CF40 is ok over stock, but the CF42 and CF45 have better results. The CF40,CF42 and CF45 are all just fine with the stock motor. I even ran a CF48 with the stock motor and esc, but I really don't recommend it that much. Stick with the 42 and/or 45 and you'll be golden.
            - Diesel's Youtube
            - Diesel's Fleet
            • leeuk
              • Jul 2011
              • 56
              sweet,thanks diesel,was hoping you or wizard would notice my thread and help me out,like ive sed before..im new to fe boats so this is a big learning curve for me so any help is great and very much appreciated.
              another quick question,when the boat is on plane..how wet should it be? at a guess i would say mine was running nearly more than half the boat length in the water but after seeing your vids it looks like your running 2-3 inch?
              • siberianhusky
                • Dec 2009
                • 2206
                A few feet of cavitation is normal on take off, if mine doesn't cavitate it shoots out of the water and rolls right over!
                It's also normal for them not to turn left as well as they do right. In a right turn the prop is helping pull the boat around, going left it is resisting turning left.
                Most race boats are not set up to turn left at all.
                The trim tabs and strut on mine are dead level with the bottom of the hull, CG between 27 and 30% from the transom, in flat water I move the packs to the 27% mark.
                Mine also runs a little looser and faster on the water if there are some ripples on the surface.
                My favorite all around prop on mine is an octura x440/3, most runs don't end up with a retrieve with this prop, in flat water or when running alone I can run a bigger/ faster prop, when there are 4 other boats on the course though the water gets pretty chopped up and all out speed is not really what finishes a race in those conditions. I'll give up some top end speed for the improved handling.
                • leeuk
                  • Jul 2011
                  • 56
                  havent really read up on cavitation but at a guess.. is it were the props spinning and sort of tries to push the rear of the boat downwards slightly until it gets momentum to drive forward??
                  i was running in flat water yesterday and was great,like ive sed,if it could get on plane easier then id feel alot happier..i didnt like how it was draggin it ass in the water but wasnt sure if this was normal for stock and was worried that because of this,it would draw more amps
                  • leeuk
                    • Jul 2011
                    • 56
                    also i would like a better water jacket,but theres a couple to choose...i like the one listed on kintec as the sv27R super-cooler..would this fit the stock sv27 1500 motor?
                    • siberianhusky
                      • Dec 2009
                      • 2206
                      Yep cavitation is when the prop is spinning but the boat is moving really slow and the transom kind of sucks down, then all of a sudden it hooks up and goes.
                      The 540s super cooler water jacket will fit.
                      The UL-1/Motley Crew and SV27r have a slightly different diameter than the 1500 blue can motor, The Proboat size coolers are also the wrong size for that motor. Just tried a SV cooler on a Proboat Geico motor and it's too small.
                      It's the cooler right under the zip ties, 3rd thing down on the page should fit, even have a picture of it on the blue can motor.
                      It takes a bit of trial and error to get it set up, change one thing at a time and see what difference that change makes, for better or worse, bring it in and try something else. I use a small digital angle finder to set up my boats, makes it very easy to get back to a set up that worked really well. When you change props you have to kind of start over again as the lift and speed really changes how the boat handles.
                      I generally leave my trim tabs set at 0* to the bottom of the hull and change the stinger by 1 degree at a time, either positive or negative depending on what the nose of the boat is doing. Unless it is really windy and rough I never have my CG more than 30%, I find it spins out in full speed turns if the CG is too far forwards. The nose digs in and the boat whips around and usually flips!
                      • leeuk
                        • Jul 2011
                        • 56
                        will prob order the 540s one then but it doesnt have the add to cart button on so im guessing there out of stock as jan told me last time that if the add to cart button isnt visible then they prob dont have them in stock
                        • leeuk
                          • Jul 2011
                          • 56
                          just emailed jan and gt an almost instant reply saying there out of the supercoolers and maybe a while til they get ome made...damn
                          • siberianhusky
                            • Dec 2009
                            • 2206
                            http://www.offshoreelectrics.com/pro...prod=ose-80030
                            here you go, from the Offshore electric store, think it's in stock. Steve is also a great guy to deal with, fast shipping turn around.
                            I have the older black version on mine.
                            • leeuk
                              • Jul 2011
                              • 56
                              Thanks buddy,will def look into that.
