sv27 with36 \56 2030kv
  • CHUD
    • 497
    diesel
    hay bud moved rudder forward and adding some more wood inside boat for batt's are thay to farforward looked at your's and I might be! The prop I can't tell what it is here's some pic's
    • Diesel6401
      Memento Vivere
      • 4203
      Rudder looks good, straighten the turn fin out a little looks to far faraward. Start with it straigth up and down. One problem you have is with those stock trim tabs. Those need to be updated either with the OSE trim tabs which I use or with the Kintec tabs. You need something with a set screw that applies constant pressure on the tab that way their not flexing up and down while running like yours will. Also avoid adding wood inside the boat for batts. Use just velcro all down the sides like I did. Your adding unneccessary weight to the boat. In the video the location I ran my boat was based on the water conditions. If their was more chop I would move them just a little more forward to keep the bow more stable, but in the video is the furtherst back I run and where I generally run them for calm to slight chop. Is that the stock prop? Swap to a metal one.
      - Diesel's Youtube
      - Diesel's Fleet
      • CHUD
        • 497
        diesel
        Will do bud! going to order ose trim tab's I cant what untill hydro get's he's in the mail it's comming from Florida; he said it's still there, he also has a green one'but all stock;[ look's like he will be eating my wake]
        • HYDROJERRY
          • Jan 2010
          • 2503
          If so ill throw in my elam and spank ya hehehehe,,,,Ps tracking on the boat shows its in louisburg,,maybe get it wet this weekend YEEE HAAAA,,,,,
          • CHUD
            • 497
            hydro
            I beat the sv27 will give that elam a run for it's money .see you for coffee in the morning
            • ggcrna
              • Apr 2010
              • 37
              Originally posted by Diesel6401 View Post
              Ul-1 power in a SV, yea click the SV link in my signature and you will see a video of it. I run mid to high 40s with mine with ul-1 power. Good choice of batts, set up properly it should be a nice running SV. For props, 42x55, x642, 40x52/3 or x440/3. My boat doesn't have the teflon tubing either. It's better if it's their, but not major just make sure the flex shaft isn't touching or can rub the stuffing tube at the end before it hits the collet
              Diesel, what type of esc do you run in your SV right now?
              Thanks, Glenn
              • Diesel6401
                Memento Vivere
                • 4203
                Thanks, Glenn
                Right now i have a aquastar 120 in it with a 7xl (i was bored). Normally I have ul-1 motor & esc in it.
                - Diesel's Youtube
                - Diesel's Fleet
                • CHUD
                  • 497
                  diesel
                  Me and hydro ran this morning and everthing was allright untill I hit a wave from some boat's that were close by I thought the boat was ok than she started to clich and than stop in the water ,she came to; and Igot her to shour the antenna came out and was in the water I put her back in and went to the other side and she stoped ;so hydro started swimming ;can it be the antenna or something else!nothing was hot ;just warm;no water in the boat
                  • ggcrna
                    • Apr 2010
                    • 37
                    Diesel: are the stock sv27 motor can and the UL 1 motor can the same diameter?
                    I will eventually replace my stock motor with the UL and wonder if I can use my Kintec jacket on the UL 1 motor . Thanks man, I viewed your collection of videos on you tube. Nice job.
                    Glenn
                    • Diesel6401
                      Memento Vivere
                      • 4203
                      Glenn
                      I know a kintec ul jackets on a sv motor will leak, Im not 100% sure about the other way around.
                      Thanks!!!
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • wizard122
                        • 483
                        No the SV and UL motors use different water jackets they are not interchangeable.
                        2 SV 27's and Vac-U-Pickle UL-1 Power
                        • Diesel6401
                          Memento Vivere
                          • 4203
                          I figured that... just wasn't 100% sure
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • ggcrna
                            • Apr 2010
                            • 37
                            thanks gentlemen.
                            • CHUD
                              • 497
                              thanks gentlemen.
                              Hay bra checked out your profile nice sv like the colorsYou should make it your avatar!Hay guy's take a look at my new toolbox for my sv .
                              • HYDROJERRY
                                • Jan 2010
                                • 2503
                                Awww das nice bra,,, when you want me to put your vid on here,,,or do you want to wait to get a better one yo!!!
