sv 27 motor
  • txboatpilot
    • 1805
    #76
    If you want to drag race you are wasting time with your HEAVY batteries!!!Drag racing is about "KEEPING IT LIGHT"!! Lipos will give you a 4-6mph increase with any prop or motor!!!
    The 2600 will make your SV SCREEM!!
    Now that I know what you have and want to do, we will get you set!
    Start with your 40x53 and then go up to the CF45 and CF48..
    Nothing like keeping you lipos warm and your prop wet!!
    • SweetAccord
      Speed Passion
      • 1322
      #77
      WOW thank you, so of these Fieago's:
      540 6XL 2,779 RPM / Volt
      540 7XL 2,382 RPM / Volt
      540 8XL 2,084 RPM / Volt
      540 9XL 1,853 RPM / V olt
      Which would you get? I want one more to spare/different motor.
      Thank you kindly!!
      • txboatpilot
        • 1805
        #78
        I run a Rigger with the 1515/1.5D (2700KV) and X640 on 4S1P lipo and get over 60mph easy in a straight line..
        • txboatpilot
          • 1805
          #79
          Try the 7XL.. It will fly on 4S lipo...
          • SweetAccord
            Speed Passion
            • 1322
            #80
            I won't be using Lipo, will that be an issue?
            • txboatpilot
              • 1805
              #81
              Only issue will be knowing that there is more SPEED and you cant get too it!!!! LOL
              • txboatpilot
                • 1805
                #82
                Do you have a extra 2300 Ammo, I need another for a twin set-up I am working on?
                • SweetAccord
                  Speed Passion
                  • 1322
                  #83
                  I only have the one 2300. Sorry.
                  Hehhee....I have EP4600 which are Trinity EastPowers. They are pretty high rated. So the SV can run a 540 7L 3,511 RPM / Volt 5mm Shaft
                  with a Hydra 120 ESC (120AMP) with no issues? Unless I go prop crazy maybe like the CF48? Any run time estimates?
                  • txboatpilot
                    • 1805
                    #84
                    You should be happy, just watch the props! Run time is hard to est. With all these motors you have bought, you should really look into lipos! They are night and day from NMHI... Read the last issue of boat modeler mag. Jay Turner has a great article on the diff. in lipo power vs. nmhi......
                    • txboatpilot
                      • 1805
                      #85
                      Metal props dont flex like CF props, so you might stick with the 40x53..
                      • SweetAccord
                        Speed Passion
                        • 1322
                        #86
                        Wonderful. I was under the impression that the 2600kv was the running limit for a SV motor in that hull. Now that I know a 7L 3,511 RPM will work too, sweet!
                        I just got all the batts and chargers, so down the road I will, i figure the batteries can be the last push, once I make it run as fast as possible on NIMH's the Lipo's will be the nitrous!
                        Do you know someone that runs that 7L 3,511 RPM in a SV?
                        • txboatpilot
                          • 1805
                          #87
                          That is 7XL not 7L!!!!!
                          • SweetAccord
                            Speed Passion
                            • 1322
                            #88
                            Oops you right, sorry, I meant the 7XL. So the 7XL 2,382 RPM / Volt is the one. Is this one slower than the AMMO 2600 due to the Kv rating or is the XL cause of the length and torque compensating for that?
                            • txboatpilot
                              • 1805
                              #89
                              If you are going to run in a straight line, remove the turn fin! It causes drag, and will free up 1-2mph..
                              • SweetAccord
                                Speed Passion
                                • 1322
                                #90
                                Remove turn fin.....writing that one down. Man this is gold, anything more?? I'm eating this all up!! You great!!
                                So is the 7XL slower than the AMMO 2600 due to the Kv rating or is the XL cause of the length and torque compensating for that?
