sv 27 motor
  • txboatpilot
    • 1805
    #61
    You can run the Ammo 2600 with a smaller prop than the m445 I run. Just run very small prop to start with, watch your temps and go up in prop size to gain more speed. Start with something like a CF40 and go from there.. Just watch the HEAT!!!
    Nothing like keeping you lipos warm and your prop wet!!
    • txboatpilot
      • 1805
      #62
      What motor are you running now?
      • SweetAccord
        Speed Passion
        • 1322
        #63
        RcPrince is running a 2600, so the hull is capable. Is this the limit?
        • txboatpilot
          • 1805
          #64
          Capable, YES.. Limit YES..
          • SweetAccord
            Speed Passion
            • 1322
            #65
            I have the stock SV motor, the AMMO 2300 and the 2600 on order. Steven claims that the Feiago's, my impression by him, are faster?? The XL in particular, stating that the XL has more torque than the L. So what is the advantage and disadvantage between the two of the same KV?
            • txboatpilot
              • 1805
              #66
              If you want a 60+MPH motor look at a 1515/1.5D (2700KV).. Run that with a M645 and you will take FLIGHT!!
              • txboatpilot
                • 1805
                #67
                The XL with the same KV can spin a bigger prop with less heat..
                • SweetAccord
                  Speed Passion
                  • 1322
                  #68
                  Ok now we are talking.....
                  • SweetAccord
                    Speed Passion
                    • 1322
                    #69
                    So the XL will be faster pound for pound over the L with the same KV with less heat? What about run time? Shorter? Which KV is the ideal one? The 8XL?
                    • txboatpilot
                      • 1805
                      #70
                      What speed have you got out of the stock motor? What props do you have?
                      • txboatpilot
                        • 1805
                        #71
                        Run time will be shorter(not much), the xl will take more mAh from the batteries.
                        • txboatpilot
                          • 1805
                          #72
                          Sometimes this stuff is hard to get a hold on! I will try to explain the best I can..
                          • SweetAccord
                            Speed Passion
                            • 1322
                            #73
                            I don't have a GPS or aything to be honest for accurate speed values. Did you see the YouTube post I did? That is a bit faster than mine. I have 440/3, 40x53,40x52/3, CF45, CF48, CF40.
                            • txboatpilot
                              • 1805
                              #74
                              The thing you need to look into is lipo's that will increase your speed more than anything..
                              • SweetAccord
                                Speed Passion
                                • 1322
                                #75
                                Ok I want to be able to drag race basically. I just want to run the limit of this hull design. I have the Hydra 120 and will be running 4600 NIMH's. I can run any prop really that is recommended.
                                All I would really like to know what is the motor that will make this hull design scream, but still make it runnable? Any ideas? I have the 2300, the 2600 AMMO. Steven stated the Feiago's are fast if not faster is the impression I'm getting.
                                So my posing question, maybe you can't answer, what will be the better motor, a L or XL. Steven says the XL. Another person says the L. What is the advantage and disadvantage of each in the same KV rating?
                                Also which would be the optimal motor KV to select that will allow a high prop. run fast and not heat everything up and allow me to tune it down, if need be?
                                I just don't want to get a motor that is useless and non runnable with any prop that I can fit on the 3/16 shaft and then have to sell the motor off. I wish to get the advise that is right on.
                                See where I'm coming from? Once again maybe you can't answer me, but I'm putting my question forward.
                                I'm willing to want for now to get the most out of NIMH, Lipos down the road.
                                Thank you, I really appreciate you helping me on this!
