Think i need more prop
  • dana
    • Mar 2010
    • 3660
    Which prop?
    • MAMBA2200
      I need a scooby snack
      • 1347
      the stock prop 42x55
      • dana
        • Mar 2010
        • 3660
        Hmm that's odd, I'm surprised it blew from that. Doesn't seem over propped really
        • MAMBA2200
          • 1347
          yes i know it didnt smoke or get hot and the eagle tree just said it had a draw of like 32amps it just died would not do anything but there sending me another but i went ahead and bought a 180a anyway
          • MAMBA2200
            • 1347
            yes you can use it on anything as far as i know i use it on all my rc planes boats cars
            • MAMBA2200
              • 1347
              well if anyone can help me out on this took the revolt out yesterday and run it first on 4s with the m545 and i got 42mph then i tried it on 5s now i have changed to the 180a esc also gave it a run and on 5s i got a whopping 41.7 so whats the deal i have a tacon 2 pole motor 3674 1900kv which i paid 36 dollars for brand new in a similar boat and in the revolt its a leopard 3674 4 pole 1900kv which i paid over 80 bucks for new and to be honest the tacon is 10mph faster than this leopard or have i just got a bum motor do i need higher timing on the leopard its at 11.25 on the tacon im at 7 so far im just not impressed with this leopard motor at all but its the first one ive owned if anyone could help with this because with all i have read on this forum my setup on 5s should be haulin and its not i am uploading video that i will post today so you can see the boat in the water and by the way the amp draw on 5s with the m545 was only 83 amps it is a short video cause i was bringing it in to check temps
              • dana
                • Mar 2010
                • 3660
                That prop is way to big
                • MAMBA2200
                  • 1347
                  it can be used on stock stuff and is good for high 40's is the stock motor more powerful than the leopard??????
                  • MAMBA2200
                    • 1347
                    would i be better off with a 4074 motor??
                    • dana
                      • Mar 2010
                      • 3660
                      To give you an idea, I run a leopard 3674 1700kv in my Titan 29 mono hull, with seaking 120 on 5s2p and x444 prop, and my speeds are right at 50. You should be way faster than me by comparison. The leopard motor is much better than the tacon. Something is not right with your setup. Not sure. Let's hear exactly what you're running. Radio batteries etc...
                      • dana
                        • Mar 2010
                        • 3660
                        Btw, you're leopard is a d wind. Timing should be 0-5 degrees tops
                        • MAMBA2200
                          • 1347
                          spektrum radio dx3c t-180 3674 1900kv leopard stock servo and sky lipo 4s 40c and 5s 40c
                          • MAMBA2200
                            • 1347
                            here is the video of the run
                            • dana
                              • Mar 2010
                              • 3660
                              Is your throttle set to reverse?
                              • MAMBA2200
                                • 1347
                                yes
