Motor choice
  • Grimracer
    • 660
    whow.. the split water line is a bad idea...
    Grim
    • MAMBA2200
      I need a scooby snack
      • 1347
      well ive had no temp issues should i not split it
      • Grimracer
        • 660
        Yep.. bad idea.. path of least resistance.. ya know.
        3rd run and you have made that many changes? Can I ask why?
        Truth is none of my "4S E stuff" seems to get over 115deg..(eagle tree sensors logged durring the run)
        Grim
        • MAMBA2200
          • 1347
          i did all the changes before i ever put it in the water but i will change it back thanks for the info the esc change is just for adjustability of the lvc
          • Make-a-Wake
            FE Rules!
            • 6057
            The prop is simply too much, if you want a reliable setup that will be as fast as it was in the vid go for the 1900kv with an m445........................all the batt and cooling stuff is irrelevant, you have way too much prop.
            • Grimracer
              • 660
              Make a wake has the concluding word..
              RELIABLE!
              the prop you have on now is MY FAVORITE prop BUT... I race my boats..I do not sport run them.
              The prop you have now is FASSSST.. but.. again. Darin said it best.. Limit your run time.
              So much to learn.. Your alright.. stick with it. We are all learning as we go.
              Grim
              • MAMBA2200
                • 1347
                ok thanks guys i really appreciate all the help that is what i will do
                • MAMBA2200
                  • 1347
                  just ordered 3674 1900kv with cooling jacket and a m445 now to get some new batteries
                  • stumblinh
                    • 52
                    I found issues with the stock motor bullets... both my revolt and my ul1, under a heavy load they simply FALL OFF. I suggest checking this as the motor will seem to not work; drop on some nice 5.5mm or so bullets with your own solder and golden.
                    • MAMBA2200
                      • 1347
                      i have 5.5 conns coming also for everything in the boat the motor never quit it just really slowed down but i thing it will work well in my recovery boat im building after it cooled down seemed to be fine gonna test it in my pool before i have to recover my recovery boat lol
                      • Tom899
                        • 91
                        Where is it best to order the 5.5's?
                        • stumblinh
                          • 52
                          get a nice pile from hobbyking for cheap.. not sure where else but even on ose's site im sure.
                          • Tom899
                            • 91
                            Mine did not fall off or even feel loose, BUT, they were leaned up against the plastic battery tray and melted a hole in it! So obviously there is some high resistance in these smaller connectors? The only mod I have is a 45x68 prop, could this be why they are getting hot, if so what should I beef up? Is there any issue with soldering the small wires to the large 5.5 connectors? Some of these 5.5's state they are for a specific wire size, such as 10awg or 12awg.
                            • MAMBA2200
                              • 1347
                              Well i replaced all connectors on mine took the water line spliter out and ordered two 4s packs 5000mah 40 c and shortened all the wires on eagle tree and esc hope this will help some
                              Sent from my DROID RAZR using Tapatalk 2
                              • Tom899
                                • 91
                                Originally posted by Mike Caruso
                                Hi Tom,
                                I installed 5.5's on mine before it hit the water not on the motor side just the battery side of the ESC.
                                Mike
                                Hi Mike, I did the same, except used EC5's. I'm thinking about changing the motor/ESC connectors but just may wait until I swap out the stock ESC with a 180, it has larger wires to work with.
                                -Tom
