Got my revolt
  • MAMBA2200
    I need a scooby snack
    • 1347
    Got my revolt
    well i got my revolt yesterday overall i am very happy here is a few things i noticed
    -all the gear on the back is way loose (no biggy)
    -i got no owners manual or stickers
    -when i turn the prop the motor wiggles back and forth
    -there was nothing holding the hatch on so its scratched allot around the hatch hole (again no prob)
    - i do have lock nuts on all hardware thats a plus
    it almost seems like i got a boat that someone else had returned but i can fix all that is needed here is a video of the motor wobble
  • Grimracer
    • 660
    Hum.. No manual.. I bettter give you the contact info to Product Support.
    Call em and see if they can get you setup.
    Grim
    Hobby Services
    3002 N. Apollo Drive, Suite 1
    Champaign, Illinois 61822
    Attn: Service Department
    Phone: (217) 398-0007 9:00 am - 5:00 pm Central Time M-F
    E-mail: hobbyservices@hobbico.com
    Also.. here
    • MAMBA2200
      • 1347
      thanks grim i have contacted omni thats where i got it from but so far have had no responce will give them a chance to make it right first
      • bruceisla
        • Aug 2012
        • 56
        You appear to have either a bad coupler or a bent motor shaft. Try removing the coupler and spinning the motor shaft to see which is bad. It's possible the coupler is cross threaded. Video is a bit shaky and too short to look closely.
        • MAMBA2200
          • 1347
          well they are sending me the missing item and i think the wobble is flex shaft which i have already got the upgraded shaft so all is good i can fix the rest
          • MAMBA2200
            • 1347
            got my seaking 120a V2 and 150a eagle tree time to start the build as everything will be here today photobucket-41902-1348319541628_zps6eb26191.jpgphotobucket-35208-1348319555490_zpsa5d93341.jpg
            • MAMBA2200
              • 1347
              well i got the rest of my parts and it was the flex shaft bent i dont see how they crammed it in there gonna call aquacraft today and see if they will send me another because this one is crap but i have the upgraded cable installed and all is wellphotobucket-15101-1348492385892_zps7b975a8e.jpg
              • bruceisla
                • Aug 2012
                • 56
                Well .... you may be expecting a bit much. Flex cables flex .... that doesn't look like a kink (sharp bend).
                • MAMBA2200
                  • 1347
                  this i know when i pulled the old one out it had like a 45 degree bend on the end of the cable
                  • stadiumyamaha
                    • 1371
                    I wouldn't bother getting them to replace the stock flex. They are so suspect that you don't want to risk losing a good prop. Many times they fail in the first couple of minutes. Jmo
                    • MAMBA2200
                      • 1347
                      i hear ya think i will take that advise
                      • MAMBA2200
                        • 1347
                        well its all done and ready for its first run here is some final picsphotobucket-35263-1348580145245.jpgphotobucket-26975-1348580127743.jpgphotobucket-18967-1348580114016.jpgphotobucket-35347-1348580158128.jpg
                        • ktodd
                          • 5
                          Looks great! Looks thirsty for water Let us know how it runs
                          • MAMBA2200
                            • 1347
                            will do im off thursday thats when the maiden voyage will be and i will video it and post it up
                            • Tom899
                              • 91
                              Looks great! And good luck on your maiden voyage! Very exciting! If you get a minute, I'm most interested in how the Seaking ESC works out for you? Are you starting out with the timing at 11.5? What do you have the LVC set at? I guess I'm most interested in what type of warning you get when your batteries start to run down. With the stock ESC there's a feature called "Studder Bump" but basically if this happens you really have no time to bring it in and you get stranded. I have taken measures to overcome this by just running for a few minutes and bringing it in while it's still running fast, but it sure would be nice to maximize my running time. Anyway, sorry for being long winded, just really interested in how well your ESC works and what kind of warning you get.
                              Thanks,
                              Tom
