Aquacraft Mini Rio stock impressions
  • Steven Vaccaro
    Administrator
    • 8932
    #61
    Hint, hint. No need to remove the stock stuffing tube. The mini cat hydro .098 flex with 3mm prop shaft fits great. its almost the perfect length also. The only change is the drive dog. It will drag unless the front(leading) edge is cut/sanded to a 45degreee angle.
    Steven Vaccaro
    • Diegoboy
      • Mar 2007
      • 7443
      #62
      I remembered that issue from this post...
      The quickest choice is the Mini Cat Hydro Cable and shaft. The only issue with that is the drive dog. Its not tappered like the stock drive dog, so the mini Cat setup will be an area of large drag if thats not addressed.
      It was either turn the minicat hydro dog on a lathe (which I don't have) or pull the tube.
      I pulled the tube!
      • Diegoboy
        • Mar 2007
        • 7443
        #63
        I also added the silicone water jacket. the inlet and outlet were opposite each other which wouldn't work. I had to correct that issue.
        Here's the result
        • Steven Vaccaro
          Administrator
          • 8932
          #64
          Turning the brass dog is easy with a belt sander. Just slowly rotate the drive dog while on the shaft. It took me about 1-2 minutes.
          Steven Vaccaro
          • Bigmax
            • 29
            #65
            I tried to hand drill out the coupler for the Ammo motor, It didn't work out.
            LOL... me too! The way I got it done was to clamp a piece of plastic I had to the table on my drill press. Drilled a hole down into it with the 1/8" bit. Then took the bit out, turned it upside down and put it in the hole. Then put the coupler in the chuck and ran it down onto the stationary bit. Worked perfectly.
            BTW, what's the part number on that jacket?
            • Diegoboy
              • Mar 2007
              • 7443
              #66
              Part # gnd-4195
              Fits 20mm to 28mm Diameter Motors. My motor is 28mm. Fits like a glove!
              • chirotray
                DocFowler
                • 139
                #67
                Hey, Diego, What prop do you think will be best with that motor? Im working on mine too.
                Yes its fast, yes it will go far away, yes its expensive. No you cant try it.
                • Capgun_Slim
                  • 7
                  #68
                  Here's the result
                  I'm such a NOOB to boats, so I really need your help guys. I finally got my Mini Rio, and I also purchased that same water jacket for motor cooling when I add the brushless. But I don't understand what you mean when you say the inlet and outlet were reversed to you fixed it. How did you fix it, or what will I need to do? Also, can you send me a link to the other parts I.E. the .098 Flex shaft? Also, where is the drive dog located?
                  Hang in there with me, as I said, I am a Noob, but everyone has to start somewhere.
                  • Diegoboy
                    • Mar 2007
                    • 7443
                    #69
                    I'm putting it together for you now...
                    • Diegoboy
                      • Mar 2007
                      • 7443
                      #70
                      Let's start with this question...
                      Originally posted by Capgun_Slim View Post
                      Where is the drive dog located?
                      This diagram should help out alot.
                      • Diegoboy
                        • Mar 2007
                        • 7443
                        #71
                        Get yourself a piece of K&S 5/32 brass tube.
                        Cut off one of the outlet tips on the jacket.
                        Drill a 3/32 hole in the opposite side of the outlet you just cut.
                        * The hole will close up with the bit removed, it's normal.
                        Insert the tube into the hole you drilled in the jacket let about 3/16 stick out the back and mark where the 2 water channels are placed on the tube with a pencil.
                        Drill 2 small 3/32 holes in one side where the pencil marks are.
                        Fill the end with solder to seal it shut.
                        file or sand the rough edges on the tube.
                        Insert the tube in the jacket positioning the holes in the water channels.
                        Cut the tube to length.
                        Done
                        • Capgun_Slim
                          • 7
                          #72
                          Diego thanks very much for the great illustrations, and instruction. I can't believe how many parts/names for that little sucker, lol!
                          • Jon K
                            • 35
                            #73
                            Do the silicone sleeves work best though? I'd think some aluminum or copper tubing around it would be better...
                            • Diegoboy
                              • Mar 2007
                              • 7443
                              #74
                              You'd be wrong. The tube is round, therefore very little surface area for cooling is contacting the motor. where as the silicone jacket, the water is in direct contact with the motor.
                              • Jon K
                                • 35
                                #75
                                Well truthfully the water is in direct contact with the silicone sleeving, which is in better contact with the motor... but silicone isn't a super effective thermal conductor
