Mini Rio First thoughts
  • Steven Vaccaro
    Administrator
    • 8724
    My batch of Mini Rio's came in today. I have to say from first glance I'm impressed with the stock boat and the promise of being able to upgrade this boat easily.
    Plus there's something to be said about being able to fit this in a suitcase to take on vacation with out an issue with space.
    First the prop is plastic, measures 30mm in diameter and sits on a 3mm shaft. Octura 1/8" props will fit but be a little large. A piece of shrink wrap on the shaft or a wrap of tape around the shaft will take up the space.
    The Mini Cat Racing USA has the mini hydro props that are carbon filled and fit 3mm props. So there is an abundance of sizes to try out.
    The drive lined up to run in surface piercing! Another plus!
    As for upgrades the cable is thin for brushless motors. I can't see it lasting a long time under bl power. I will be looking for upgrades for this area. The quickest choice is the Mini Cat Hydro Cable and shaft. The only issue with that is the drive dog. Its not tappered like the stock drive dog, so the mini Cat setup will be an area of large drag if thats not addressed.
    I will be trying the stock motor first. I would like to try a 3s pack. Will have to wait and see if the stock electronics are up to the task?
    Thats it for now.
    Steven Vaccaro
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    I have recently come into the friendship of a club member that has a lathe. I can get a bevel put on one easily.
    • Steven Vaccaro
      Administrator
      • 8724
      Its always nice to have a friend with machine tools!!
      Steven Vaccaro
      • OJ racer
        • Dec 2007
        • 170
        Hey Steven, you said earlier you had just recieved your first batch of Mini Rios, does that mean OSE will stock them soon? I live close to Boston, so thanks to shipping times, I would definitely be an eventual buyer if you are going to carry them.
        • Steven Vaccaro
          Administrator
          • 8724
          I have them at the store now.
          Steven Vaccaro
          • OJ racer
            • Dec 2007
            • 170
            When will they be on the net?
            • wamf
              • Mar 2008
              • 75
              I'm using a octura x431 and it fits fine. Using a solder gun I removed the cable from the shaft and inserted a .047 wire. Also found that some antenna tubes fit snug in the stuffing tube.
              MikeV
              • Steven Vaccaro
                Administrator
                • 8724
                MikeV
                good idea!! Did you use a solid wire? If so, this will really help with bl power!
                Steven Vaccaro
                • wamf
                  • Mar 2008
                  • 75
                  It is .047 piano wire. The cable seemed to be holding up well with 2s lipo. The reason I switched is that it was pulling a lot of water into the boat.
                  MikeV
                  • Steven Vaccaro
                    Administrator
                    • 8724
                    Mike good job with the upgrade! Did you glue the wire in the shaft or solder it?
                    Steven Vaccaro
                    • wamf
                      • Mar 2008
                      • 75
                      Steve I was planning on gluing it but wanted to try soldering first. I sanded the end of the wire to rough it up then cleaned it with electronics cleaner. Using a solder gun it worked really well, maybe because of the small diameter
                      Ran it today and only picked up a few drops of water. Now it's time to buy another boat.
                      MikeV
                      • Steven Vaccaro
                        Administrator
                        • 8724
                        Thanks for the info. Whats the next move?
                        Steven Vaccaro
                        • wamf
                          • Mar 2008
                          • 75
                          Ugh.... buy another boat I only want to go so far on this one and it sounds like someone else will do the full trick out.
                          I want something about 20" with BL and a long run time. Get your mind out of the gutter.
                          MikeV
                          • Jesse J
                            scale FE enthusiast
                            • 7241
                            Was looking for a comparison of pond boats thread and seems most appropriate. I am looking at getting 3 identical boats for our pond (50' x 30') and am considering the options: mini cat, mini v and mini rio. Need to stay around $100 and RTR. I would like to have options of taking to larger ponds, and am thinking MiniRio, but like speed so MiniCat.
                            In anybody's opinion, what is best all around boat? and also allows for upgrades? How different are the MiniCat and MiniV as far as speed - would there be a distinct advantage if racing against each other?
                            "Look good doin' it"
                            See the fleet
                            • Diegoboy
                              Administrator
                              • Mar 2007
                              • 7247
                              Leaving it stock? get the Rio.
                              Brushless Mod? Mini-C or Mini-V.
                              Mini-C is a better hull all around, but harder to mod than the mini-V
                              I have modded all 3, If I were to do another one, It would be the Mini-C!
