49.9mph Using M440 Octura
  • detox
    • 2310
    #46
    I will check the Deans temps this evening also.
    • detox
      • 2310
      #47
      OK I am back from the pond. It was 5:00PM when I ran UL-1 so the winds were still blowing and water had more chop than I like for speed runs. Second run lake was more calm than first run.
      First Run Using the HEAVIER 4s2p 6600 mah combo. The heavier weight help UL -1 handled a little better
      49.1mph max speed
      Close to 5 minute runtime
      Dean's temps 159-161 degrees
      Battery temps 131 degrees
      motor 119 degrees
      esc 121 degrees
      Second Run Using the LIGHTER 4s1p 5000mah combo. The lighter weight caused propeller to jump in and out of water causing wide voltage spikes. Thus popping a another cap. Or maybe cap was still too hot from the first run building even more heat then popping the brown capacitor fluid inside hull.
      49.6mph max speed
      3 minutes (popped a cap?)
      Bullets...did not record temp
      Stutter and LVC test: Again the boat stuttered then died very quickly so I had to wade to retrieve it. Second run I popped another cap so boat just died on water, but would rearm to bring back to shore. I will try two caps next time...Two caps should run cooler.
      Here are pictures...I will try to get video one day
      • Capt. Crash
        • Jan 2009
        • 301
        #48
        Some of those temps are pushing it....bad on battery! Good info..thanks!
        Were you using the M440?
        • detox
          • 2310
          #49
          No...I was using the Grimracer L40 x 57/3
          In this UL-1 I have seen battery temps reach 170 using new Flightpower batteries. These G3 batteries run cooler.
          • detox
            • 2310
            #50
            EDIT: Next I will try to get the most out of the UL-1 by using different prop angles, prop depths, and props. Lead ballast also.
              • 9479
              #51
              Originally posted by Grimracer View Post
              The UL-1 Speedo has a SB (Stutter Bump) system as well as a LVC (Low Voltage Cutoff).. The UL-1 SB comes in at 12V and the LVC at 11.6. Just so you know we did not pick those numbers out of a hat.. We have tons of data regarding lipo discharge and also qualified our finding with some of the fastest FE RC boaters in the world.. True!
              From our testing we have found about 15 to 25 second from SB to LVC.. more then enough time to get the boat back to shore.
              Haivng said that there is certanly NOTHING wrong with only using part of the MAH the batts provide..
              Hope this helps
              Grim
              Today my SB came in and 3 seconds later it stopped, but was very close to shore
              I love this boat!
                • 7990
                #52
                Not really, good cells can handle 140F+ without damage - the internal resistance is lower at high temps. Over 160F is where good cells can start to go bad, although I prefer not to exceed 140F-145F personally. Heating the cells before running - or running them at an ambient of ~100F - is easier on the cells.
                • detox
                  • 2310
                  #53
                  I love this boat!
                  My LVC came on MUCH SOONER than 15 - 25 seconds...more like 3 seconds after Stutter Bump. But I still love the UL-1
                  • alvinsmith75
                    • Jul 2008
                    • 635
                    #54
                    I ran mine today and @ 2min 53 sec with y537/3 boat stopped and then started back up. The hottest thing was the motor at about 125 degrees. What could this be?
                    here is vid
                    It looks like I stopped but it just so happened to be coming towards me when it happened.
                    • jingalls007
                      • 1015
                      #55
                      you might be over propped. Next run change it up with a new prop, see if you get the same results.
                      • alvinsmith75
                        • Jul 2008
                        • 635
                        #56
                        I'll go with the y437/3 thanks.
                        • detox
                          • 2310
                          #57
                          Could have been the Studder Bump Grim was talking about or...
                          Today after running my boat I noticed 4mm banana plugs (female esc side) started to become unsoldered. If these wires seperate boat will briefly stop then restart. I will soon switch to beefier Castle 5.5 bullets. These beefier versions will not get as hot as the CHEAP factory versions .
                          I think maybe the heavier weight and longer runtime using 4s2p caused this
                          • alvinsmith75
                            • Jul 2008
                            • 635
                            #58
                            Oh yeah I forgot to mention that when I put my batteries on the charger they were at 15.6 volts. I will try new connectors and 437/3 prop.
                            • jingalls007
                              • 1015
                              #59
                              Jay Turner runs 5.5 bullets on his UL-1, he said you might see a speed increase as well when switching to the larger bullet connectors.
                                • 9479
                                #60
                                More speed with bigger connectors, cool!
