49.9mph Using M440 Octura
  • detox
    • 2357
    Today using Grimracer L40 x 57 my UL-1 went 48.9 mph and boat handled perfect with no chine walk and no cavitation that I noticed.
    Grimracer L38 x 55 was about the same speed as L40 x 57 and boat handled verywell.
    Grimracer L38 x 63 too much chine walk
    Octura 2140/3 too much stern bouncing, chine walk, and slower
    Octura V940/3 too much stern bouncing, chine walk, and slower
    Octura m440 went 49.9 mph and boat handled verygood (my favorite prop so far... motor temp 119, esc 93, batteries 115)
    Al testing was done with strut set 1 1/8" below hull and turn fin was angled upwards slightly according to setup board. My new G3 Hyperion 2s 25c 5000mah packs were faster than my older Flightpower 2s 25c 4900mah packs (new packs are allways faster). Jeff Wohlt .078" wire drive and custom .078" OSE Octura collet worked perfectly. I will try to get video soon.
    God I love the UL-1! Turn fin area has no cracks either. Throttle was held wide open in turns!
  • EPower
    • 417
    Al testing was done with strut set 1 1/8" below hull and turn fin was angled upwards slightly according to setup board. My new Hyperion 2s 25c 5000mah packs were faster than my older Flightpower 2s 25c 4900mah packs. Jeff Wohlt .078" wire drive and custom .078" OSE Octura collet worked perfectly. I will try to get video soon.
    How do you like your new batteries are they up to your expectations
    • detox
      • 2357
      So far so good...I ran them all the way down to the Low Voltage Cutoff. Boat never slowed down before hitting LVC, but stuttered then died very quickly on pond. The Flightpower batteries did slow down more noticably before hitting LVC.
      • LuckyDuc
        Team Ducati Racing
        • Dec 2008
        • 1058
        Nice write up on the props. I may order a M440 to test with for a heat prop. I wonder how much the results would differ between the stock flex cable and the wire drive setup you tested with?
        • detox
          • 2357
          The UL-1 Motor loves to spin high so I am sure the .078" wire helps free up some RPM's. I may test stock cable vs. piano wire next.
          • jingalls007
            • 1172
            thanks again for sharing this info. I put a .150 hughey flex in mine with an Octura Collet, bad idea, collet didn't grab flex shaft and boat didn't move. Put back stock shaft and collet, no problems. I will order my M440 this week.
              Why was that a "bad idea"? The Octura flexhexes work great, apparently there is something wrong with your parts. Are you certain the cable is 0.150"? Is the flexhex for 0.187" cable? Did you put anti-seize on the collet threads and cone?
              • jingalls007
                • 1172
                Flex hex for 5mm to .150, same as flex shaft at .150. I may have had the flex hex to fat down on the drive shaft of the motor so the flex shaft may have not been inserted far enough in the hex flex to really hold it tight.?
                • detox
                  • 2357
                  Collet needs to be TIGHT, but not overly tight. Tighten until you poot. If you crap you went too far.
                  • detox
                    • 2357
                    I puchased a pair of $5.00 extra strong +3.00 reading glasses from Walmart to help see LOTS better while sharpening all my props.
                    Here's some good sharpening instructions:
                    • detox
                      • 2357
                      Today my UL-1 went 50.2mph using the Grimracer L40 x 57/3 prop. Water conditions were smooth as glass with a very slight wind chop here and there. This Grimracer prop is now my favorite because it handles ruff water better than two blade prop. Mike knew what he was doing when he designed this prop for the stock UL-1.
                      More attention to detail during sharpening should make prop faster. Any ideas?
                      • Capt. Crash
                        • Jan 2009
                        • 341
                        I got 50.0mph out of my old dull 40X57/3 this weekend too.
                        • detox
                          • 2357
                          I converted my UL-1 batteries over to Castle's 6.5 bullet connectors. I am using 7/16"OD x 5/16"ID clear Vinyl tubing as an insulator (purchased at Homedepot). I also replaced just the factory male motor connectors using Castle's 4mm male bullets.
                          • LuckyDuc
                            Team Ducati Racing
                            • Dec 2008
                            • 1058
                            Did you notice that your connectors were building heat?
                            • jingalls007
                              • 1172
                              Good idea!! I've noticed my deans getting a little warm as well.
