UL-1, Steering
  • silvermansteve
    • Aug 2009
    • 152
    UL-1, Steering
    i broke the pushrod connector, what i might have called a clevis, connecting the rudder pushrod to the servo arm. is this the correct replacement? i can't look because i threw it out.... here:
    http://www3.towerhobbies.com/cgi-bin...?&I=LXMNN4&P=7
    thank you!
  • m4a1usr
    Fast Electric Addict
    • 2036
    Thats the critter. At least if you want to go stock. I would recommend you move the servo arm from the top, arm pointing up, orientation to pointing down. If you look at the angles my own opinion is you get a tad more torque or force by making the change. Nothing scientific, just my dos centavos.
    John
    Change is the one Constant
    • silvermansteve
      • Aug 2009
      • 152
      i'll check out re orienting the servo arm when i put it back together. thank you very much.
      • silvermansteve
        • Aug 2009
        • 152
        that was not the right part, too small not the same. just posting to clarify is all, in case someone orders it....
