lipos that fit ????
  • Rob DeAngelis
    • 296
    lipos that fit ????
    any suggestions for hi mah hi c lipos for the UL1?
    Lakeside entertainer
    • 7512
    http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
    All you will need.
    • JimClark
      • 5913
      take some measurements of your boat and then look at the different sites to see what will fit there are dimensions on the batteries on the web pages
      Billy Graham
        • 7512
        These fit...used them all last season.
        • detox
          • 2357
          Without going too heavy I like the Hyperion 4s 3300mah packs. Wire two of them parallel 4s2p for a total of 6600mah. They will fit cross ways or inline with hull.
          • m4a1usr
            Fast Electric Addict
            • 2036
            Do the sponson mod and you will be able to fit most if not all 4S packs inside. I dont have a link to the modification but its here on OSE. The mod also reduces sponson walk at high speeds.
            John
            Change is the one Constant
            • Rob DeAngelis
              • 296
              Thanks guys...
              • Rob DeAngelis
                • 296
                I hear ya... I was looking into that...
                John
                • G-UNIT
                  • 971
                  Cut openings in the sponsons and put the batterys in the openings, this will give you more stability a higher speeds, I did this with a 1500kv motor on 6s and it was great but nail biteing@ 63.3mph on gps, but I normally run 5s and will be going back to a stock set up and run 4s and see what the best speed I can get with different setups, I'm sure the best I could would be mid to high 50s, but spading the batterys does help with handling and room.
                  I run 5000 mah 40c-50c batterys
