upgraded prop
  • flyingjunky
    • 32
    upgraded prop
    I replaced my stock prop with a grim racer L40x57 today and it will not get on a plane, even after hand launching several times. Do i need to bend the shaft????
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    Lower the strut to approximately 1 1/8". With larger or more agressive props you will need to adjust and tune the strut.
    • h2o 1
      • Sep 2011
      • 770
      DO NOT BEND THE SHAFT!! balance and sharpen that prop, then lower ur strut depth in small increments until you find it sweet spot. worked for me !!
      • Diesel6401
        Memento Vivere
        • 4203
        The prop also needs to be very well sharpened and balanced
        - Diesel's Youtube
        - Diesel's Fleet
        • flyingjunky
          • 32
          Balanced and sharpened the prop. Lowered strut and it's better. just seems that I have to start out slow and let it build speed. Before with the stock prop i could tap throttle, let the front bounce and when it coumes back up hit WOT and instant speed. I might have to play with the adjutments some more.
          • flyingjunky
            • 32
            Could not get it to plane yesterday. No matter what i did it just would not lift. Put the stock prop back on and no propblem at all. I do not get it.
            • Diesel6401
              Memento Vivere
              • 4203
              The L40x57/3 has to be very VERY well sharpened. If its not razor sharp it will give you issues. Keep trying it, once it hooks il for you its wicked fast.
              - Diesel's Youtube
              - Diesel's Fleet
