ESC help
  • speedfreak
    • Mar 2010
    • 54
    ESC help
    where can i find a good and cheap ESC. i know at hobby king but which one. I think my problem might have to do with the ESC or the RX. so i'm going to give it a shot at the ESC first because the RX light is still on. thanks
  • Diesel6401
    Memento Vivere
    • 4391
    I read your other thread, I would troubleshoot a little more before just assuming its the esc. If you really want a new esc though, heres some links.
    I run this one myself and like it and the program box is very nice. http://www.hobbycity.com/hobbyking/s...ter_Cooled_ESC
    http://www.offshoreelectrics.com/pro...=hef-sword-120
    Just don't get anything less than 60 amps and you'll be ok, also the hobbywing/turnigy 180amp big esc's don't fit in the hull so stick to the slim design.
    - Diesel's Youtube
    - Diesel's Fleet
      • 7512
      Have you tried adding a new cap on the controller, its a simple fix that may help,,,some where on here there is a thread about it.
      • speedfreak
        • Mar 2010
        • 54
        what causes the cap to go bad do you know? all i did was leave the batteries connected for a couple of days when i was done running. when i came back the batteries were shot and now the boat won't even turn on, the rutter turns though
        • speedfreak
          • Mar 2010
          • 54
          also where can i get a cap?
            • 7512
            The cap on the early models of the UL-1 was under rated and sometimes just died, a local electrinic shop might have better rated ones. I have been trying to find the thread on here about replacing them, but not havng any luck. PM a member here called LiPo Power, he started that thread.
            • speedfreak
              • Mar 2010
              • 54
              thanks, i'll try to look for it. I've got the newer UL-1.
              • Diesel6401
                Memento Vivere
                • 4391
                Good add Doby, an extra cap was the first thing I added to my ul-1 before I even ran it. Here's where I got mine from. http://www.kintecracing.com/Electrical.html (scroll towards bottem). Very easy to install and prob the best first step and also the cheapest.
                - Diesel's Youtube
                - Diesel's Fleet
                • Diesel6401
                  Memento Vivere
                  • 4391
                  Does it have the huge cap hanging off of it? If not its not a new gen.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • speedfreak
                    • Mar 2010
                    • 54
                    yeah it's got the huge cap on it, so how do i take that off, i found the tread on how to put it on, somebody said to just leave it.
                      • 7512
                      Leave it on and solder a new one to the power wires.
                      • detox
                        • 2357
                        Sometimes the thin motor wire connectors will get too hot and will become unsoldered. This will cause motor not to run. I replaced my cheap UL-1 connectors using Castle's BEAFIER 5mm versions.
                        • speedfreak
                          • Mar 2010
                          • 54
                          i finally got the motor to turn, i put channel 2 to channel 1 and the motor armed. which then to me must mean that channel 2 is shot. so i probably have to get a new rx or does anyone have any ideas. has this happen to anyone before.
                          • LiPo Power
                            DJI Drone Advanced Pilot
                            • 3678
                            Here it is, please read it all.....
                            http://forums.offshoreelectrics.com/...ead.php?t=9828
                            Canada
                            • wizard122
                              • 535
                              RX
                              Any 2 channel futaba AM rx will work 75MHZ
                              http://www3.towerhobbies.com/cgi-bin...?&I=LXMRE6&P=7
                              or this on Ebay
                              http://cgi.ebay.com/OFNA-2-Ch-Radio-...item2eacd61d82
                              http://cgi.ebay.com/Novak-Polaris-AM...item439ec59c99
                              2 SV 27's and Vac-U-Pickle UL-1 Power
