UL-1 powered 68 Miss Bardahl
  • Capt. Crash
    • Jan 2009
    • 341
    Which of my props will work best on this UL-1, 1:10, powered boat. I don't want to hand launch.
    Here is all I have...all grim props.:
    38-55/2
    40-52/3
    40-57/3
    She is not completed (cockpit and tail and graphics...etc) but I'm giving her the maiden tomorrow.
    I have the 38-55 on her right now but I've never tried that prop. Do I need to go with a different one?
    Crash
  • JimClark
    • 5913
    typically a 45mm to 47mm works well
    Billy Graham
    • Capt. Crash
      • Jan 2009
      • 341
      Hey Jim...you do get around...lol
      The above is all I have in the box that would even work with this motor. Which would you try first?
      • JimClark
        • 5913
        38 is way to small not sure on the 3 blades. I certainly would not judge how well it performs with those props
        Billy Graham
        • JimClark
          • 5913
          By the way I am contemplating a 1/16th scale checkerboard Bardahl. What did you use for the yellow? Where did you get the color code for it? I think I have a couple 45mm RH Graupner carbon props that work well,. If I do I could send you one.
          JIm
          Billy Graham
            • 9481
            is this hull the same in size as the UL-1?
            if so anyone of those props will work and the 40-57/3 will work great!
            • JimClark
              • 5913
              nope it is 1/10th scale 36 inches long
              Billy Graham
                • 9481
                a 45mm to 47mm prop could be to much with this motor
                BJ power it will work great, but I'm not so sure with the UL-1 motor?
                • JimClark
                  • 5913
                  you might be right maybe a 40 or 42 to start just not sure of the 3 blade
                  Billy Graham
                  • Hydromaniac
                    • 955
                    I hope you have better luck in your 1/10 with a UL-1, We have burnt up a couple of them, a 36 inch boat needs some torque, Good Luck. Start with about a 42 MM prop, something like an X442 and go up from there if your temps are safe. Make short runs to start with.
                    www.rockymountainthunderboats.org
                    • Capt. Crash
                      • Jan 2009
                      • 341
                      Ok...thanks guys...I 'll go back to the 3 blade and hope she will get on plane. I didn't think a couple of inches would make that much difference between this and the UL-1, hence the UL-1 power...I guess I will find out tomorrow.
                      Jim...I'm using plain ole Rustoleum rattle can yellow. It takes a long time to dry but seems to work well and the the Rustoleum Gloss Clear dries quick to the touch and looks pretty good on top of it.
                      • BHChieftain
                        Fast Electric Addict
                        • 2051
                        Did you paint the black checks or use decals?
                        If painted, how did you do it?
                        -Chief
                        • JimClark
                          • 5913
                          they are vinyl
                          -Chief
                          Billy Graham
                          • Capt. Crash
                            • Jan 2009
                            • 341
                            What props?
                            Here is a video of the sail yesterday with some cracker, UL-1 and the Miss Bardahl footage. I got a cool running 39.7 mph with a conservative 40-52/3 prop 1st day out....I should be able to shake more out of her with some tuning.
                            Crash
                              ..I didn't think a couple of inches would make that much difference between this and the UL-1, hence the UL-1 power...
                              Hmmm, 36"- 27" = 9" is a bit more than a "couple of inches"....
                              The UL-1 motor is really not well suited for this large hull, that's probably why the hydro falls off in speed so much in the corners. The boat catches enough air to run reasonably well in a straight line, but overall performance would be better with a BJ or SV motor and a larger prop. It would also get on plane easier. Did the boat thermal in the video? If not, just two minutes of run time to LVC indicates a pretty high amp draw - what cells were you running?
                              If you insist on running this motor, you'll need to flatten the strut or move weight back a bit to stop the transom hopping - this causes amp spikes which are extremely hard on the ESC. Otherwise it is a beautiful boat, can't wait to see it completed.
