Water inlet/outlet tubing
  • Drag Boat Bob
    • Apr 2009
    • 304
    Originally posted by Colby View Post
    Then you are not talking about the :
    Click picture for details! Product ID: aero-2014
    Aluminum Bulkhead Fitting
    In Stock: 64 Details
    Aluminum bulkhead fitting for large size silicon tubing.
    Price: $2.89
    because this thing looks plenty long enough ... or are you talking about the:
    Click picture for details! Product ID: etti-a029
    Water Inlet/Outlet fitting 4mm
    In Stock: 7 Details
    Water inlets/outlet for a smooth 4mm hole. They can be glued in for ease of installation.
    Each package contains (4) in total
    I have the aero 2011 Large Water Outlet, but the body looks to be the same length as the aero 2014. Mine is 7/8" long (body only) and 1" overall.
    The etti fittings are for motor water jackets and about the same size as the ones on your stock water jacket.
    Hope this helps...
    • Colby
      • Dec 2009
      • 54
      Hope this helps...
      Yes it does and thanks! I'm a newbie to the RC boat arena and have read all your posts last year regarding prop testing. So now it being a year later, what is your favorite prop?
      • Drag Boat Bob
        • Apr 2009
        • 304
        I still have a couple that I haven't yet tried, but so far I still like the L38x63. It is not the fastest (50mph), but it seems to help my driving skills. A lot of guys use the L40x57-3 with very good results.
        From time to time I put on the L42x66, but have to keep an eye on the temps.
        Bob
          • 9481
          Bob
          Wow, how does she run with the 42x66?
          sounds like a lot of prop..
          • Drag Boat Bob
            • Apr 2009
            • 304
            Yeah it really is. 53mph avg with much better control than the m445. Next prop is going to be the Octura 1938. That is if the wind ever dies down.
            Fired up the Vegas to pre-breakin the Novarossi motor. Holy crap what a difference from the Super Tiger. Not even on the same planet...
            • Capt. Crash
              • Jan 2009
              • 341
              The pretty alum bulkhead fitting i used was not long enough to get through both bulkheads. What I ended up with was the fitting butted up to the alum tubing connected with a short piece of fuel line all hidden inside the transom. I then sealed under the fitting and around the tubing where it comes out the inside bulkhead with clear silly cone. It don't leak so I'm happy.
              Crash
                • 9481
                Bob, how were your temps with that prop?
                • Drag Boat Bob
                  • Apr 2009
                  • 304
                  Ever since I moved the water fitting locations on the stock water jacket (now goes in on the side and comes out on the top) my motor temps have been lower. If I remember correctly, the motor runs about 130-135 and the ESC 100-105. I keep the runs to around 3-3.5 minutes. So far, so good...
                    • 9481
                    Thanks man!
                    I will give that prop a try this spring..
