Water inlet/outlet tubing
  • Colby
    • Dec 2009
    • 54
    Is the tubing used for routing the water same as the fuel line tubing used for nitro RCs? Which size is it? How difficult is it to get the tubing out and back through the hole in the transum? On my stock UL-1 the inlet tubing that goes from the top of the rudder got cut/chewed up by the prop. For now I got a plastic cupler (used for sprinkler tubing) to reconnect the two ends after I shortened them slightly but would ultimately like to replace the entire tubing. I gave it a slight tug to see how difficult it was going to be to get it through the transum and it did NOT budge. Anyone have experience on replacing the inlet water tubing?
    Thanks for the feedback.
  • Diesel6401
    Memento Vivere
    • 4391
    Yes its fuel tubing you can pick it up at any local hobby shop 3/16 outside diameter works fine. I used a drill bit to ever so gently clean the hole up to allow the tube to go in. Shouldn't take longer than a minute if that to install.
    - Diesel's Youtube
    - Diesel's Fleet
    • Colby
      • Dec 2009
      • 54
      Thanks for the info Diesel ... I'll get the tubing tomorrow. Once you run the new tubing back through the transum, did you put any glue or anything between the new tubing and the transum?
      • Diesel6401
        Memento Vivere
        • 4391
        No need. Right tubing size should be perfect fit.
        - Diesel's Youtube
        - Diesel's Fleet
        • Jeepers
          • May 2007
          • 2050
          Colby it can be a bit of a pain to get the tubing back through the transom and the "sealed" radio compartment I would recommend putting a piece of brass tube through both and epoxy it into place much easier!.
          • Colby
            • Dec 2009
            • 54
            Thanks Jeepers, I'll consider that as well. I did see a thread (UL-1 Performance and Modification: A Thread Summary) where a Capt Crash did just that but with an aluminum rod.
            • tharmer
              • 342
              They also make a really cool aluminum thru-bulkhead fitting that looks really classy.
              -t
              • bwells
                • Jan 2009
                • 847
                Try cutting the end of the tubing at a long angle and insert it enough to grab with needle nose pliers and pull. If you're going through 2 hulls or the hull and radio box, cut a longer angle
                  • 9481
                  that's just what I did with my UL-1
                  I picked up some clear water line for the ice maker of a fridge.. the inside dia is much bigger than the stock tubing
                  • Colby
                    • Dec 2009
                    • 54
                    -t
                    Who makes these fittings? Do you by chance have a link?
                    Thanks
                    • Drag Boat Bob
                      • Apr 2009
                      • 304
                      Thanks
                      You can pick them up right here on OSE.
                      About half way down the page.
                      http://www.offshoreelectrics.com/products.php?cat=66
                      • Colby
                        • Dec 2009
                        • 54
                        Thanks, I just checked them out. Do you know which size works best with the UL-1?
                        • Drag Boat Bob
                          • Apr 2009
                          • 304
                          I bought the large one. The problem with the one I bought is that it is the same length as the distance between the transom and the inside of the tub. This means it does not extend into the tub for hose attachment or the nut. That may be the reason Crash used the aluminum tubing with it.
                          • Drag Boat Bob
                            • Apr 2009
                            • 304
                            With that impressive Cat color scheme, I thought you would have found some shiny black water line...
                            • Colby
                              • Dec 2009
                              • 54
                              Then you are not talking about the :
                              Click picture for details! Product ID: aero-2014
                              Aluminum Bulkhead Fitting
                              In Stock: 64 Details
                              Aluminum bulkhead fitting for large size silicon tubing.
                              Price: $2.89
                              because this thing looks plenty long enough ... or are you talking about the:
                              Click picture for details! Product ID: etti-a029
                              Water Inlet/Outlet fitting 4mm
                              In Stock: 7 Details
                              Water inlets/outlet for a smooth 4mm hole. They can be glued in for ease of installation.
                              Each package contains (4) in total
