Noob and ul-1 w/ lipo
  • Diesel6401
    Memento Vivere
    • 4391
    Question, so i'm new rc 's and new to lipo's. My question is that I currently run 2x 2s zippy 4500mah 30c lipos. I want to add some more voltage to my boat. Being since the batteries run in series can I run a 2s 4500mah 30c lipo with a 3s 4500mah 30c to equal 5s? As long as the "C" and mah ratings are the same voltage really shouldn't matter since their added together anyway. Is my thinking correct or am I way off?
    - Diesel's Youtube
    - Diesel's Fleet
  • 6S HYDRO
    • 1325
    yes but dont run longer than 1 min.
    • Diesel6401
      Memento Vivere
      • 4391
      Y is that? I would like more run time, how could accomplish that without changing esc?
      - Diesel's Youtube
      - Diesel's Fleet
      • 6S HYDRO
        • 1325
        no chang motor and esc to accommodate 5s, maybe a 1300-1500kv motor and at least a 150 amp esc
        • Diesel6401
          Memento Vivere
          • 4391
          Sorry I meant to say without changing esc, I edited the above statment. So instead of going to 5s would more amps make a difference in perfomance, say 5000+mah at 40c or 50c? My goal is to provide best battery power without changing the stock esc/motor. I currently run 2s 4500mah 30c zippys like I said above I also have some 2s 4000mah 25c tenergys I run in my SV. I really like the perfomance of the lipo's it's amazing. I truly noticed the difference in my SV. My ul-1 is fast enough for me right now. I run a x440/3 and I love the perfomance and heat is not an issue at this time. I am just trying to gain some knowledge on best setup solutions for this boat. So far I have 0 complaints and am truly loving rc boating . Just a whole lot to learn, I've only been in for 3 months.
          - Diesel's Youtube
          - Diesel's Fleet
          • 6S HYDRO
            • 1325
            get the 40c 2s batteries, or get 2 4s 3700 batteries and run them in parallel for 4s2p
            • Diesel6401
              Memento Vivere
              • 4391
              I found some 2s 4000mah 40c's on HC I may go with. Thanks so much for all the help.
              - Diesel's Youtube
              - Diesel's Fleet
              • wizard122
                • 535
                Hi Diesel check out these thread http://forums.offshoreelectrics.com/...ad.php?t=12248 found it yestrday
                2 SV 27's and Vac-U-Pickle UL-1 Power
                • Diesel6401
                  Memento Vivere
                  • 4391
                  Hey what's up wizard. Sweet I'll have to give those a try and order them when I get a chance. Did your pond freeze up over the last few days? The part of lake norman that I normally run at was surprisingly frooze. Are you running those in your SV?
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Diesel6401
                    Memento Vivere
                    • 4391
                    Hey wizard those turnigy 5000 40c's are out of stock at HC. These are the ones you have correct? http://www.hobbycity.com/hobbycity/s...dProduct=10305
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • 6S HYDRO
                      • 1325
                      those are the ones- dont do a 4000 pack it wont have as many amp discharge. 5000 mah and higher for boats. the 2 3700's would be 7400 mah and 80c
                      • Diesel6401
                        Memento Vivere
                        • 4391
                        I run 4000 25c in a SV and 4500 30c in a ul-1. You think this is too low? I run for maybe 5-7ms, the stutter bump or lvc has never tripped on either boat
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • 6S HYDRO
                          • 1325
                          just calc it out 25c 4000mah= 25 x 4 or 100 amps
                          30c 4500mah= 30 x 4.5 0r 135 amps
                          40c x 5000= 200 amps
                          you want to only use 70 percent of your amps so if your ul-1 is pulling 90 amps peak (whick most do) you would want batts that provide 30% more amps than your pulling so
                          ul-1 pulling 90 amps with 135 amp batts
                          70% of 135 is 94.5 amps so your right there, the 40c would give you 65 amps more leeway
                          • 6S HYDRO
                            • 1325
                            hence the 40c's will prob never puff out on ya
                            • Diesel6401
                              Memento Vivere
                              • 4391
                              Cool, I will have to wait until the get back in stock. Do you happen to know what SV's peak at?
                              - Diesel's Youtube
                              - Diesel's Fleet
