How Fast are you running?
  • linn
    • Dec 2012
    • 13
    How fast are you running with the stock motor and esc on 4s? The only thing I did was two prop changes and grease the flex cable.
    I'll start:
  • D&D
    • Aug 2009
    • 185
    Mine is an Areomarine Mean Machine, NEU 1515.1Y, Castley Hydra HV180, on 4S2P Lypos: 57.5 MPH.
    • linn
      • Dec 2012
      • 13
      Sweet, but what does that have to do with a stock motor and esc?
      • D&D
        • Aug 2009
        • 185
        Did you mean a stock RTR boat and setup? If so, sorry, that is not what I read into your thread. There are those who hop up, modify, their motors and esc...... Anyway it will be fun to see the replies you get to your thread. By the way what are you running (boat, motor, esc) to get to 45MPH?
        • linn
          • Dec 2012
          • 13
          Everything in my boat is 100% stock and both props I tried are also straight out of the box with zero work. I'm running two 2s 5600 50c packs.
          • linn
            • Dec 2012
            • 13
            So no one else on here has made top speed runs with the stock motor and esc?
            • linn
              • Dec 2012
              • 13
              Since no one else posted, does that mean I have the fastest stock motor/esc Motley Crew? If not who can prove me wrong?
              • linn
                • Dec 2012
                • 13
                I broke 50 today :) and think there is more left in the boat all runs have been made with untouched props. No thinning or balancing yet
                • linn
                  • Dec 2012
                  • 13
                  I went 58.8 today on the stock motor and esc. my goal is to get video footage and break 60 this coming weekend. Still running untouched props.
                  • dirtnsnowrider
                    Great Basin Aquaholic
                    • Apr 2012
                    • 314
                    I would like to see some hardcore proof. I was testing a friends motley today with the stock set up and a balanced and sharpened prop. It was no where near 58.8mph. In fact I spent over 2 hours tunning his boat for him and the boat woke up with a 48mm prop (plastic for test purposes) and some 40 c packs on 4s. I have read your posts and you do not list anything except its stock. What batteries are you running? What is the angle of your strut? What is the COG of the boat? Where are your batteries placed? What untouched prop are you running? Just saying its stock with untouched props smells fishy. If it is in fact true, how about some real info on this as it would really be beneficial to other owners who spend a lot of time tunning their boats.
                    • Heaving Earth
                      • 1877
                      So how many times did you gps to verify the gps reading is correct?
                      • Grimracer
                        • 656
                        Remember.. when using a GPS.. AND.. the boat blows off.. it will read the blow off speed NOT the on the water speed.
                        You can use a GPS but just keep this in mind..
                        Grimracer
                        • D for Dummy
                          www.dfordummy.com
                          • Mar 2012
                          • 55
                          Grimracer, do you have any testing data to share? Asking for data with stock motor and stock esc, any battery and prop data you've collected for this would be nice. :)
                          By the way... My stock Motley Crew with a pair of 2s 4500mAh 65c and GR 42x55 prop with positive strut angle and batteries to the rear is faster than a stock Blackjack 29 with a pair of 2s 4500mAh 35c and X440 and also x442 prop.
                          (THANK YOU!)
                          Aquacraft: Revolt 30, (Three) Motley Crew / ProBoat: 1/12 Miss Budweiser, Stiletto 29 / Venom: P1 KOS Fountain with all Revolt 30 hardware
                          http://www.youtube.com/user/dfordummy/videos
                          • Grimracer
                            • 656
                            I have lots of data.. Let me get caught up on some stuff here at work and see what I can come up with.
                            Thanks YOU!.. its the users of the products that are most important. Its dudes like you that we want to do each and every product better and better!
                            Cheers
                            Grimracer
                            • linn
                              • Dec 2012
                              • 13
                              Hey, guys I'll try to get some updates for you later this week, I keep jumping back and forth between two props the ABC H5 and H7. I've ran 4 different sets of batters 2s 6000 mah 35c, 2s 5000 mah 40c and 2s 5600 mah 50c. The best speed has been with the 50c batteries and the strut is what I call out as far as I can get it, with having a buddy tighten the strut bolt/nut. I run the boat as dry as I can without it porpoising.
                              Once the boat hit 50.4 MPH I thought it was time to step it up, so I tossed in a set of 3s packs with no adjustments in the strut the boat ran 58.8 with the H5 on batteries that were only about 75% charged. I also had to control porpoising with the throttle as it was extremely dry. I felt like I was making a 100+ mph run in one of my RC cars.
                              I'll get videos of it this weekend breaking 60.
