I just put in a 2000kv Leopard and a seakink 180 and the boat hauls but the tail just wiggles and it chine walks vary bad any help would be great
Death wobble
Tags: None
Are you talking about the AQ Motley Crew cat? It's pretty unusual for a cat to chine walk, I've never seen it myself and have always seen it as a mono trait. My first step would be to check is the ride surfaces with a straight edge to make sure there is no hook or rocker pulling each side down in turn freeing up the other.Paul Upton-Taylor, Greased Weasel Racing.
I got it a lil better by moving the batteries forward a bit but still a handful. And yes it is a mc I also blueprinted the hull and checked it when I was done with a straight edge and it was flat. What do you think the cf should be?Brappp
I also notice the boat is ‘twitchy’ when driving varying the speeds (like when maneuvering around the dock) making it tricky to steer. I am thinking it is due to the standard AQ 6 pole motor being very strong and notchy and causing drag from the prop. The prop is acting like a brake, and making it veer to the side. When cursing mine runs predictably and relatively straight.
I got a MC, Stock it is great, not extremely fast, but handles Fantastic!
Do you have a video of yours running? Would love to see one faster than what this hull wants
Just ordered an upgraded flex shaft from OSE (just in case) and also a m445 prop. ESC and motor will be next after I squeeze everything out of the stock stuff.
