Death wobble
  • slow-at-rc
    WANNA RIDE BIKES :)
    • 94
    Death wobble
    I just put in a 2000kv Leopard and a seakink 180 and the boat hauls but the tail just wiggles and it chine walks vary bad any help would be great
    Brappp
  • NativePaul
    Greased Weasel
    • 2764
    Are you talking about the AQ Motley Crew cat? It's pretty unusual for a cat to chine walk, I've never seen it myself and have always seen it as a mono trait. My first step would be to check is the ride surfaces with a straight edge to make sure there is no hook or rocker pulling each side down in turn freeing up the other.
    • slow-at-rc
      WANNA RIDE BIKES :)
      • 94
      I got it a lil better by moving the batteries forward a bit but still a handful. And yes it is a mc I also blueprinted the hull and checked it when I was done with a straight edge and it was flat. What do you think the cf should be?
      Brappp
      • Barbossa
        • May 2011
        • 30
        I also notice the boat is ‘twitchy’ when driving varying the speeds (like when maneuvering around the dock) making it tricky to steer. I am thinking it is due to the standard AQ 6 pole motor being very strong and notchy and causing drag from the prop. The prop is acting like a brake, and making it veer to the side. When cursing mine runs predictably and relatively straight.
        • jjenkins
          • Jul 2011
          • 20
          I got a MC, Stock it is great, not extremely fast, but handles Fantastic!
          Do you have a video of yours running? Would love to see one faster than what this hull wants
          Just ordered an upgraded flex shaft from OSE (just in case) and also a m445 prop. ESC and motor will be next after I squeeze everything out of the stock stuff.
          • v-spec
            • Jun 2009
            • 940
            Mine runs perfect in the mid to upper 50's it's on rails. If I ever get time off work I'll get a video up.
