How hot is to hot
  • Mike whiting
    • 120
    Also what temps do I want to see
    • v-spec
      • Jun 2009
      • 940
      Originally posted by Mike whiting View Post
      Do you de tongue the x442 also? Has anyone seen pics or a vid on how to de tongue a prop
      Just sharpen, balance and put it on.
      • Mike whiting
        • 120
        Added to the list of props
        • v-spec
          • Jun 2009
          • 940
          Whatever props you end up using just do a short run, check temps often. I've run the AQ 1800kv motors pretty hard and they are tough. I try to keep my temps below 120F.
          • Mike whiting
            • 120
            Well just ran again 5 min 4s m445 temps 130 motor and 118 esc then got another desolder
              • 7990
              With temps like those, most likely your problem is cold solder joints which are not strong enough to handle a little heat. What solder are you using, and what wattage iron? What tip on the iron?
              • Mike whiting
                • 120
                I am not going to lie I suck at soldering It's just a 40w. 120v with a square tip but I need to get a point
